SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 11-03-2012, 10:36 PM   #1
niterat
niterat's Avatar
Drives: ZLI IOM Convertible
Which tire pressure gauge to trust?
My DIC says the front tires are 28# and the rears are 33#. My little hand held dial gauge say the fronts are 33# and the rears are 37#. Anybody got any info on which might be more accurate, and does it matter that the fronts are a little less than the rears?
niterat is offline   Reply With Quote
Old 11-03-2012, 10:48 PM   #2
justindewoody
Drives: 2013 Camaro ZL1
They should all be at 35 psi.
2013 Camaro ZL1 Silver Ice #3187 TPW 10/22
1100 Preliminary Order Accepted 9/26/2012
1102 Preliminary Order Added Thru Web 9/26/2012
2000 Accepted by GM 10/01/2012
2500 Preferenced 10/02/2012
3000 Accepted by Production Control 10/02/2012
3100 Available to Sequence 10/11/2012
3300 Scheduled for Production 10/11/2012
3400 Broadcast 10/18/2012
3800 Produced 10/22/2012
4000 Available to Ship 10/23/2012
4150 Original Invoice 10/23/2012
4B00 Bayed 10/23/2012
4200 Shipped 10/26/2012
4800 Rail Ramp Unload 11/02/2012
5000/6000 Delivered 11/05/2012
justindewoody is offline   Reply With Quote
Old 11-03-2012, 10:56 PM   #3
Supermaro585HP
Drives: 2011 Camaro SS RS
Check them after car sets over night in the morning. I went through this shit for a week. LOL Set them at 36 (SS) ? (ZL1) reset the dic and drive a few miles. Your dic will show higher numbers as the tires get hotter from driving. Again check them in the morning if your car is in a garage. Hope this helps man... Go to Advance and get a digital gauge. Get a good one.
Supermaro585HP is offline   Reply With Quote
Old 11-04-2012, 09:35 PM   #4
DangerZL1
Drives: Future ZL1 Owner
I use a digital accugauge and my DIC is only off about 1 PSI on one tire. I run 32 in them.
DangerZL1 is offline   Reply With Quote
Old 11-04-2012, 10:53 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
32 is recommended
Old 11-04-2012, 10:59 PM   #6
Ladybugsmom
Older than I look....
Ladybugsmom's Avatar
Drives: 2010 VR Camaro 2SS/RS LS3
According to the owners manual, they should all be at 36psi cold.... I noticed my manual tire gauge was always about 5psi off from the DIC. Got a new manual gauge, and it matched. I now go with the DIC (had some big issues after rims changed, and after going through deep standing water.... now resolved, but I was testing it a LOT during that timeframe.)
High Heels and Fast Wheels!!
Ladybugsmom is offline   Reply With Quote
Old 11-04-2012, 11:20 PM   #7
SlingShot
SlingShot's Avatar
That's for the SS, the ZL1 is different ... Should be 32 cold
Old 11-04-2012, 11:48 PM   #8
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I'd trust the handheld gauge more than the DIC. My handheld gauge is always about 3-4 psi more.
I think GM intentionally shows a lower psi on the DIC. This makes owners pump up their tires way before the tires are dangerously underinflated.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 11-05-2012, 11:30 AM   #9
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
I'd trust a good hand-held gauge more . . .
Short of that, at least use the same gauge whenever you re-inflate the tires and don't be too afraid to experiment with slightly higher or even lower indicated pressures (since you won't know if your hand-held reads high or low unless you go get it calibrated somehow).
Don't be afraid to try a little stagger in your pressures either. A little more pressure in the fronts (2 or 3 psi) will make the car respond a little more crisply to steering wheel inputs, and setting the rears to a little less than the fronts gives them a little more margin against the car's tail "going loose" under a little too much throttle on corner exit. You might find that you prefer the car's handling behavior that way.
Norm
Norm Peterson is offline   Reply With Quote
Old 11-05-2012, 12:00 PM   #10
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Norm
Yup, what he said. Stagger them with fronts about +2-3psi over rear.
69NMYSS is offline   Reply With Quote
Old 11-06-2012, 01:54 PM   #11
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z06 3LZ & '15 RH Z/28 #0631
liquid filled analog gauges are my favorite
The pressure gauge can always be replaced with an even more accurate liquid filled gauge, but there are several from JEGS this is one at 48.00 plus shipping; accuracy is not cheap.
http://www.jegs.com/i/Intercomp/541/...oductId=937095
The_Raging_Bull is offline   Reply With Quote
Old 11-09-2012, 01:08 AM   #12
niterat
niterat's Avatar
Thanks for all the tips. I have a few dial gauges (not very expensive) and they all read the same so I'm betting the DIC is off. I will probably invest in more accurate tool just for my piece of mind. I also intend to take the advice and try a couple of different pressures to see what works best for me.
Old 11-09-2012, 06:47 AM   #13
compuwiz1937
Drives: 2012 Corvette, 2007 STS
Your gauge is probably wrong. The tire pressure system is very accurate.
compuwiz1937 is offline   Reply With Quote
Old 11-09-2012, 07:35 AM   #14
Norm Peterson
It cannot be any more accurate than how well within the permissible electrical and physical/mechanical tolerances the bits inside your specific sensors are. And that's assuming that all of your sensors are fully within spec.
Norm
