| 3rd Generation Camaros 1982-1992 Camaros |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Camaro Convt RS,2011 Camaro RS Join Date: Mar 2009
speedometer
i came across a couple of weeks ago that my speedometer was not working so i don't not how fast i am going. i took it to the shop and they could not find out was wrong with it. has this happen to any body and if so what was the problem. the good thing is i no my car for 7 years i can feel i fast i am going or i just stick to the other drivers and hope there going the speed limit. can any1 help me out on this.
![]() TEAM LLT 1992 Camaro Rs Convertible ![]() 2011 Camaro 1lt Rs ![]() |
Iroc's Love Slave
Drives: 3 Camaros, 1 Vette, a Buick, & a 57 Join Date: Jul 2008
Check to see if the speedometer cable is firmly secured to the tailshaft of the tranny.
Camaros:87 IROC-z, 95 Z/28, 2010 RS/SS
Corvettes: 90 Vert Has anyone seen my sanity? I am hiding from it and don't want it sneaking up on me! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
I think the cable connection can go bad on the gauge side as well if the tranny side looks ok.
#4 | |
i already had the shop take a look at it and it was working fine. is there like a senser that could read this in any way or a fuse.
#5 | |
would i have to take the whole cluster off or is there an easy way
#6 |
If it needs to be replaced then yea the cluster has to come out. There is a way to test it from the transmission side I forget how.
#7 | |
how would i remove the knob for the light switch i had trouble the other day and i did not want to force it out and brake it.
#8 |
![]() Drives: Silver Camry Join Date: Mar 2009
VSS Sensor maybe?
#9 |
Iroc's Love Slave
Very much a possibility. 25thanniversary, this would be the sensor on the transmission.
Here is a link to Autozone about the sensor.Autozone VSS sensor Sensor go bad all the time. In fact we replace more aircraft sensors than anything else.
#10 |
thanks on this one i was going to look into it but i did not know what is was called thanks. how would i know if it's bad or not or should i just change it any ways and see if it works.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 91 RS Vert, 2011 1LT IBM Join Date: May 2009
There is no sensor to my knowledge. I have had this happen on my 84 Chevy Monte Carlo. The coil in mine had gone and had to be redone. You should locate a shop that deals in repairing Speedometers or Tacometers. It cost like 50 bucks to have it re done. You can also swap it out for one that was in a junk yard. You wouldnt need to swap the entire cluster out. All you would have to do is take the Speedo out.
#12 |
![]() Drives: 1987 Camaro IROC-Z 350, 5spd Join Date: Sep 2009
Mine's dead too - in fact the needle actually feel off as well onto my carpet. Geez.
Ready for another one.
]1987 Camaro Iroc-Z, 350tpi, 5spd, t-tops, flat black, 4 wheel disc, posi, susp lowered 1.5 inches.
2010 Dodge Challenger SXT. |
#13 | |
I just got mine fixed it was the cluster they changed the speed sensor and everything turned out it was the cluster. the only bad news for my car since it had 69,000 when it broke i don't know how much miles it has now. but yes change the cluster and it should fix the problem
| Thread Tools | |
| Speedometer on LT vs SS | Myssi | Cosmetics and Lighting Modification Discussions | 17 | 04-06-2011 04:48 PM |
| ls3 V8 Top Speed | Kelton00912 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 167 | 12-05-2009 12:41 PM |
| Do you look at your speedometer or the DIC | Scott@Bjorn3D | 5th Gen Camaro SS LS LT General Discussions | 59 | 06-07-2009 12:28 AM |
| Speedometer Question | VenomZ302 | 5th Gen Camaro SS LS LT General Discussions | 11 | 01-29-2009 05:09 AM |
| BRAND NEW 2009/2010 Camaro INTERIOR SPYSHOTS (MAY '08) | asrapid | Camaro Photos | Spyshots | Video | Media Gallery | 207 | 08-31-2008 05:47 PM |
