Old 11-04-2012, 03:20 PM   #1
Arsenal11
Drives: 2010 2SS
E85 Tune?
So I am interesting in switching to e85 for my SS but i am not sure if its completely worth it yet. I have some nearby e85 stations so it isn't that difficult to find. However, I have some questions I hope you guys can help me with.
1) How much rwhp gains should i expect? I've read between 15-20, is that accurate?
2) Is there a way to switch between 93 and e85 with a flip of a switch? (one of my friends with an evo has it done)
3) Where can I get the tune? (heard about the trifecta e85 tune) Will it erase my current tune I have done on the car? Or should I just go back to my original tuner and see if he can do it.
-thanks for the help
Arsenal11 is offline   Reply With Quote
Old 11-08-2012, 11:12 PM   #2
Clinc
Clinc's Avatar
Drives: 2010 Camaro 2SS
Unless your running high comp or forced induction, Don't waste your money. It is not worth it and will kill fuel milage.
Clinc is offline   Reply With Quote
Old 11-18-2012, 11:59 PM   #3
redredrage
redredrage's Avatar
Drives: 2010 Camaro SS manual all stock
Hey if you get that odb2 plug in sensor that works with torque.
You can watch your engine adjust its long term fuel trim.
Since e85 is at the gas pump here in Iowa. When I'm empty I put in 5 to 6 Gallons of e85 then 10 gallons of 89.
Should put you over 93 octane and save you 7 bucks.... city driving didn't really affect mileage. High way its reduced as expected because computer adds fuel.
redredrage is offline   Reply With Quote
Old 11-20-2012, 12:08 AM   #4
CiscoBee
Drives: 2010 Camaro Rally Yellow 2LT
I had the E85 tune in my Bumblebee for 2 weeks before Hurricane Sandy hit. After the storm, getting just regular gas was nearly impossible , forget about E85, so I switched the tune back to regular fuel.
If you are running E85 you cannot use regular (87,89,91,93) gas. You have to re-tune the car. I have the Trifecta tune so I am able to switch back and forth with my laptop.
My impressions after just 2 weeks of using E85. Your gas mileage will be about 5 mph less. My price of Sunoco 93 was $4.39 at the time and E85 was $2.99 (now its $3.39).
So at $2.99 I was saving over $1.30 a gallon on fill-ups ($25 per tank) and as my daily driver (car has over 79,000 miles), I fill up at least 2x a week. I couldn't feel a noticeable gain in torque, but with only 2 weeks of seat I wasnt surprised.
As the price of E85 and Super gets closer, then the savings don't add up and without the ability to use regular gas (like in Flex fuel vehicles), if I am in need of E85 and can't find a station, I am stuck!!!
So you are probably better off staying with your current set-up. Just get the regular Trifecta tune if you want to wake the car up. Send me a PM and I can let you know price and info on tune.
CiscoBee is offline   Reply With Quote
Old 11-20-2012, 04:32 AM   #5
incon3037r
GMHIC
incon3037r's Avatar
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT
I made nearly the same power with less boost, which is a sign of the wonderful effects of E85!!
I initially made 736 RWHP / 642 LBFT SAE w/ a 4" pulley (15psi) on 91 octane. I then switched to a 4.5" pulley (13psi) and tuned on E85 and made 730 RWHP / 621 LBFT.
I still plan on running a 5" pulley to see how much lower I can power it down. I'll probably end up around 690 RWHP or so at approximately 11psi.
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 9psi on E85 9psi using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners
incon3037r is offline   Reply With Quote
Old 11-20-2012, 06:03 AM   #6
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
Talk about different, dont hear about people taking power out of their cars very often.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 11-20-2012, 09:15 AM   #7
incon3037r
GMHIC
incon3037r's Avatar
Well I'm still on the stock bottom end and the verdict is still out on the 6L80. I'll have to keep the power down until I address these issues among other things such as the gears, axles, drive shaft and more suspension parts. Plus I'll have additional belt wrap with the larger pulley and 600+ rwhp is plenty power for a daily driver.
Old 11-22-2012, 07:55 PM   #8
redredrage
redredrage's Avatar
He has a v8 and you don't... apples and oranges
