ADM PERFORMANCE
Old 11-04-2012, 04:47 PM   #1
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Whats the coldest temp, you have waxed your car in?
I wanted to get 1 more coat on her before winter and just got done, It is 37 out right now ,brrr , Anyways waxed was streaking pretty good on me, and was very hard to get off, I went thru a ton of microfiber towels , But hey it is done and now i feel better because i had not waxed it since labor day . Still have not had to put my snow tires on, ( I have all-season on now) , But now i can sleep better knowing she is ready for the white stuff, Bring it on and hurry up spring!!!
MBS is offline   Reply With Quote
Old 11-04-2012, 06:23 PM   #2
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
I've waxed my car in the garage in low 40's temps, no problems.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 11-04-2012, 06:29 PM   #3
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2012 Camaro 2SS Convertible
I have done my truck in the 30's
Ryan
Ryan
* 2012 2SS Camaro Convertible Ashen Gray
Car Build: http://www.camaro5.com/forums/showthread.php?t=257256
Old 11-04-2012, 07:03 PM   #4
knitetrain05
Drives: 2012 Camaro SS 45th Anniversary Edi
Did the wax even dry? (Reason for streaking)
knitetrain05 is offline   Reply With Quote
Old 11-04-2012, 07:23 PM   #5
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Barely, I streaked quite a bit and had to be wiped many times , The final wipe off was the hardest you really had to give it some elbow grease to get it off, But better than waiting till the spring
Old 11-04-2012, 09:16 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Hate to break it to ya but you just completely wasted your time. The streaking and difficulty to remove are signs that the wax didn't cure enough to create a bond to your clear coat.
Personally I never wax once the ambient temp falls below 70 degrees. Below this I've never successfully done an acceptable wax job. I waxed my car once in 60 degree temps and after 2 weeks the wax stopped beading, compare this to my normal 4-5 months.
You will need to wax it again on a much warmer day or if you have to ask a buddy to borrow his garage and use a couple heaters for a couple hours. If you don't your wax job may last till Thanksgiving and it most certainly won't last till Christmas.
Old 11-04-2012, 10:48 PM   #7
Ladybugsmom
Older than I look....
Ladybugsmom's Avatar
Drives: 2010 VR Camaro 2SS/RS LS3
I waxed mine in the garage at about 45 degrees. When it was warmer the next day, I noticed streaks. Easy enough to fix, but it was at a show, so it was a bit of a pain....
High Heels and Fast Wheels!!
Ladybugsmom is offline   Reply With Quote
Old 11-04-2012, 11:08 PM   #8
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Should not have done that.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 11-06-2012, 09:33 AM   #9
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Should be nice this weekend if you're outside. I've been in my garage as cold as 37 outside, but got the temp up to 45 in the garage for the LSP. (Seal and wax) This weekend is probably our last chance though to get the 5th Gen's tucked away. If your close to Milwaukee, let me know if you need any help.
WiSSDiver is offline   Reply With Quote
Old 11-06-2012, 09:52 AM   #10
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
It was in the 40's back in 88 in South Korea working on a Army Major's Corvette north of Seoul. Man it was cold!
Old 11-06-2012, 11:45 AM   #11
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
41* is the lowest I've ever worked in... but with the move to CO I'm sure I'll find out how bad it can be in the middle of winter.
Old 11-06-2012, 02:58 PM   #12
Coop
Drives: 2010 Camaro 1SS
Dylan since you moved to CO how about coming to OK and detail my car while giving me a class on how to do it? What do you say?
2010 Camaro 1SS Inferno Orange Magnusson Supercharger Installed and Tuned by ADM Performance, Roto Fab CAI IOM painted, MBRP Cat Back Exhaust, Barton Industries Short Shifter, Clear Image Headers, Pedders coilovers, BMR Front/Rear sway bars Trailing Arms and End Links, VMax ported TB
Coop is offline   Reply With Quote
Old 11-06-2012, 04:17 PM   #13
Ryanbabz71
Ryanbabz71's Avatar
I did mine today. It was about 45 and it went on and came off fine
Ryan
Ryan
Old 11-06-2012, 05:27 PM   #14
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
probably the coldest was in the 50's, firgured with direct sunlight the surface temp would closer to 60ish.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is online now   Reply With Quote
