Cold Air Inductions
Old 11-06-2012, 05:02 PM   #1
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
JANNETTY RACING ZL-1 NO TUNE PULLEY ROTOFAB TESTING RESULTS
Pay Very close attention because I don't want to lose anyone.
We learned a lot today some of it good some of it not so good.
It is in the Mid 40s here today so I wanted to re baseline the car with just the 10% overdrive with logging and found 2 things out pretty quick THESE TIRES SUCK IN COLD WEATHER and traction on the dyno was an issue that proved to be hard to overcome.
This reduced Measurable torque which translates into, HP Torque X RPM / 5252 = HP.
Where in warmer weather we had 510 RWHP and 510 RWTQ we cam up with 506 RWHP and 490 RWTQ due to tire slippage, but at least it was repeatable over and over again.
Now Some of this I can also attribute to Learning down to the Low octane table due to the added boost, I had driven the car around a bit and also refueled today before we went on the dyno.
So, on to the Rotofab CAI, The Quality Fit and Finish if Fantastic especially with the Carbon Fiber Coating.
The Fuel Trims are Perfect I put about 10 miles on the dyno with load cycling up and down the MAF Curve, Very Impressive.
WOT the AFR Repeated the Stock Air Box again Very Impressive made 6 pulls.
Boost Gain up 1 PSI to 1.2 PSI at the top.
Here is the BAD News, We Are Up Against the ALL MIGHTY HP LIMITER, OCTANE!!!
With manifold pressure reaching 12 psi on the stock tune knock retard became a Problem with the 10% overdrive pulley and Rotofab Cold Air kit combined, I will come back to this.
This intake by it self will be very good easily in the 30 RWHP RANGE, WAIT TILL THE END BEFORE YOU DRAW A CONCLUSION.
So I re installed the 5% pulley with the Rotofab CAI and Made another 6 pulls and repeated the 514 RWHP with less knock retard, AGAIN OCTANE IS LIMITING US HERE NOT THE PARTS
10.4 PSI is about all the stock tune will tolerate.
OK, back to the 10% pulley, Rotofab and a can of TORCO to near full tank, making about 97 octane, 541 RWHP 528 RWTQ.
This Graph reading from the bottom up is STOCK, VS 5% PULLEY VS 10% PULLEY VS 10% PULLEY ROTOFAB CAI WITH TORCO.
So in conclusion the parts are doing everything promised providing we have the octane.
We are looking for NO Tune Options this is a GREAT PACKAGE
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 11-06-2012, 05:12 PM   #2
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
So what were the HP/TQ numbers with the 5% OD pulley and the CAI, and is this a combo that can be ran without a tune? Will knock retard hurt the motor? In Cali, the highest pump octane we have is 91 octane.
69NMYSS is offline   Reply With Quote
Old 11-06-2012, 05:23 PM   #3
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
A Little confusing.
Question 1.
Can the 10% pulley in combination with the Roto Fab be used without throwing a code?
Question 2.
What is the gain from baseline?
Question 3
Same questions as above but with the 5% pulley?
rpepka is offline   Reply With Quote
Old 11-06-2012, 05:43 PM   #4
JANNETTYRACING
All testing was done on 93 octane until we added TORCO
Power was 514 with 5 % and Rotofab
On 91 octane I suggest only a 5% over pulley Without a tune
Ted
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 11-06-2012, 05:44 PM   #5
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Ted,
I'd like to see the HP Tuners scan with just the 10% overdrive pulley. I'd like to see what the timing advance was at WOT. I have the 8.6 inch ring on order from you guys. I would hate to think it was a waste of money.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 11-06-2012, 05:47 PM   #6
rpepka
rpepka's Avatar
Ted
Hi Ted,
So can we do the 10% on 93 octane with the CAI without throwing a code and what would be the gain from baseline?
Thanks,
Ron
Old 11-06-2012, 05:52 PM   #7
rpepka
rpepka's Avatar
Looking at the other tread, 510hp with the 10%.
Looks like it would be best to do one part or the other at this point.
Old 11-06-2012, 05:55 PM   #8
69NMYSS
69NMYSS's Avatar
Ted
I will buy a 5 gallon bucket of TORCO not a problem.
- I am assuming knock retard is when the motor automatically pulls timing due to detonation? If the motor automatically compensates for the knock, then do we have to worry about anything?
- So what you are saying is we can install the 10% OD pulley and the CAI, run 97 octane (via TORCO additive) and get about an 80rwhp increase over base WITHOUT a tune and WITHOUT hurting the motor?
Old 11-06-2012, 06:55 PM   #9
rpepka
rpepka's Avatar
Ted,
Thank you very much for taking the time to test, it is very appreciated.
Old 11-06-2012, 07:12 PM   #10
ace32x
ace32x's Avatar
Drives: 2013 ZL1
So with 92 I'm better off with a 5% pulley and te roto fab intake. 10% would start pulling timing due to knock retard?
ace32x is offline   Reply With Quote
Old 11-06-2012, 08:57 PM   #11
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Originally Posted by rpepka View Post
Ted,
Ted, I will be calling you in the morning. The CF option is not on your web site yet.
FSTORG5 is offline   Reply With Quote
Old 11-06-2012, 09:15 PM   #12
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z06 3LZ & '15 RH Z/28 #0631
Ted
93 octane with ethanol, or 93 octane w/o ethanol?
The_Raging_Bull is offline   Reply With Quote
Old 11-06-2012, 09:39 PM   #13
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Would meth injection help with this problem?
BSR-1 is offline   Reply With Quote
Old 11-06-2012, 10:25 PM   #14
JMAC2011
MONGOOSE
JMAC2011's Avatar
Drives: 2011 SS Camaro M6
I'd imagine that going to a larger cam would allow more fuel to be used for cooling. I wonder if going to a larger cam with increased overlap and slightly decreased LSA will give you a little more room to put some timing back in it before knocking??
_________________________________
MODS: 470 RWHP / 447 RWTQ
Lethal Racing Night Fury 231/242 113-111, C5R chain, dbl springs, Comp pushrods.
ARH 1-7/8" Headers and complete exhaust - NO cats!
Varraram CAI - Vmax throttle body, ATI 10% underdrive pulley
RPS Street Twin - MGW Shifter
3.91 gears + DSS 1000hp axles
PFADT - Stage 4 Camaro Road Racing Kit - 8" springs 325# and 600# - ZL Spec Sway bars - Strut Tower Brace - Camber plates.
CTSV front calipers - Hawk DTC 30 pads
Street: Forgestar F14 20x9 and 20x11, 275/315 Nitto Invo's, Track: TOYO R888 285/35/20 on 4 corners
JMAC2011 is offline   Reply With Quote
