Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Specific Models / Packages > Camaro 1LE Forum
Old 11-07-2012, 10:36 AM   #1
caverman's Avatar
Drives: '69 SS Convertible
1LE front sway bar end links?
I thought I read where the 1LE front end links were different than the FE3 (stock '10 SS) front end links. I think someone mentioned they were a little thicker plus they used a 12mm bolt vs 10mm bolt.
Can someone confirm the 1LE end links are bigger. If they are and I wanted to add them to my SS I'm guess I would have to drill out the bolt whole a little to make them fit?
Build Journal
Old 11-07-2012, 07:56 PM   #2
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Yes ZL1/1LE front sway bar links are 12mm I had to drill out my stock v6 struts to get them to bolt on
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 11-07-2012, 08:30 PM   #3
Cuda7050's Avatar
Drives: 2012 SS LS3
The 1LE front sway bar end links are indeed bigger with 12mm bolts just as you thought.
Cuda7050 is offline   Reply With Quote
Old 11-07-2012, 08:54 PM   #4
L99CAMA2011's Avatar
1LE front endlinks are same as ZL-1 front endlinks.
