Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 11-07-2012, 11:00 PM   #1
bwolf11
bwolf11's Avatar
Drives: 2012 Camaro ZL1/2018 ZL1 1LE
Tires Rubbing
Does anyone hear some rubbing when making tight turns at slow speeds?
I park in a garage with epoxy floors and mostly notice when making the turn out sounds like tires are rubbing the inner well!
No noise when wheels are straight.
bwolf11 is offline   Reply With Quote
Old 11-07-2012, 11:13 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Have you pulled a tire yet and looked for rub marks on the inner fender to verify?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 11-08-2012, 01:25 AM   #3
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
Make sure that the dealer removed the spring spacers when they did the PDI If you have to tow it the spacers need to be put back in for clearance on the flat bed. Might be causing your tires to rub.
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 11-08-2012, 06:05 AM   #4
bwolf11
bwolf11's Avatar
Yes the spacers are removed. Just got to either look into fender wells or pull them off again and look.
TY....
Old 11-08-2012, 06:26 AM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
noisy clutch packs in rear is my guess. Get the fluid changed. How many miles? I changed mine at 1k and it was disgusting. You need the special part # fluid(in owners manual) with GM additive.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-08-2012, 06:40 AM   #6
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
no rubbing here, suspect just noise you hear from the flooring, which mine do this on the ZL1 and my Avalanche.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 11-08-2012, 07:56 AM   #7
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
My tires make a lot of noise when backing slowly.
Old 11-08-2012, 09:16 AM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
What's probably happening is that the limited slip differential is doing its normal job of trying to keep the two rear tires rolling equally. That will then try to keep the car from turning, and when the front tires are on a relatively slick surface (which I suspect the epoxy surface is), they'll be more likely to be sliding a bit as they roll. As they slip more than just a tiny bit (tight turns), expect some sort of sound to be generated.
When you aren't turning, the LSD isn't trying to slide the front tires at all.
Norm
Norm Peterson is offline   Reply With Quote
Old 11-08-2012, 09:17 AM   #9
bwolf11
bwolf11's Avatar
No evidence of inner wells showing rubbing. What would clutch packs have to do with it? Never even heard of clutch pack fluid? The noise is coming from the front tire area anyway and only when slow in a turning radius
Old 11-08-2012, 09:20 AM   #10
BlackinBlack
BlackinBlack's Avatar
Drives: 2016 Corvette Z06 Blade Silver
The clutches they are talking about are in the rear end....
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD>
Roto-Fab CAI
2010 2SS/RS BLACK on BLACK <SOLD>
3" MBRP 304 Stainless Exhaust
Roto-Fab CAI
BlackinBlack is offline   Reply With Quote
Old 11-08-2012, 09:21 AM   #11
Norm Peterson
Limited slip differentials require a specific "friction modifier" additive to keep the clutch packs that perform the "limited slip" function from chattering as they slip to permit the wheel on the inside of the turn to rotate slower than the wheel on the outside of the turn. But that's more of a "chatter". A rubbing sound is more likely to be the front tires sliding.
Norm
Old 11-08-2012, 09:30 AM   #12
bwolf11
bwolf11's Avatar
The slidding part makes sence...ty....will look into changing the fluid you mentioned. 3600 miles!
Old 11-08-2012, 10:29 AM   #13
Chevrolet Customer Svc
Drives: GM Vehicles
The best thing to do is to get a proper diagnosis at a dealership. Please let us know the outcome.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 11-08-2012, 10:53 AM   #14
bwolf11
bwolf11's Avatar
Will do....but I have to get it there to do that....hahah. PIA to make appointment....
