Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 06-05-2009, 11:44 AM   #1
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Camaro Pfadt Race Engineering Coil Overs
Pfadt Race Engineering Camaro Coil Over System
Pfadt Racing brings you one-of-a-kind adjustability and performance with our Coil Over System. This system was engineered with the performance street driver in mind as well as the weekend track enthusiast. As an Engineering firm, we don't believe that an off-the-shelf shock body is the appropriate solution for your Camaro.
Some will tell you that if you've got 16 positions of damping adjustment, 15 of them will be wrong. We would argue that for 16 cars you need 16 unique settings, not to mention the needs of dual-purpose (street and track) cars. Our single damping adjuster controls both compression and rebound. The range of adjustment provides a wide range of damping to accommodate both daily drivers and dedicated track cars. For example; most people like to drive to and from work with our coils set around 8, while for track days they'll turn increase the damping to 12.
If the adjustability intimidates you it's only because it's something new for you - not because it's actually hard to do. Moreover, if you don't want to adjust them you don't have to. We supply recommended starting points that offer a well balanced, well engineered setup that we run on our own cars. It's the best of both worlds! If you end up with a product that doesn't offer adjustable damping, your only option for setting up your car will be to change springs. If you change the springs without the ability to adjust the damping accordingly, you've just ruined the "perfectly balanced system" that you thought you bought.
One of the key advantages of our coil over system is the flexibility with setting ride height. Our shock bodies are fully threaded and thread into (or out of) the lower mounting cup giving you the ability to adjust the overall shock length by about 3 inches. It's no problem to maintain stock ride height or drop it nice and low. The important thing about changing ride height by using our threaded body is that you don't have to sacrifice shock travel to lower the car.
Compared to the stock SS Camaro, our coil overs are approximately 50% stiffer. Pfadt brand components are strong, lightweight, tested for dependability and durability.
Here are some key features:
1. Mono Tube Design
2. Inverted for less unsprung mass
3. 16 points of damping adjustment
4. Adjuster is on the bottom of the shock and no tools or lifting are required to make damping adjustments
5. 0 to 3 inches of ride height adjustability without sacrificing shock travel
6. Suggested starting points, knowledgeable tech support
7. Strong dealer network and outstanding product support
We have more exciting products in the pipeline including our Adjustable "Street" and "Race" sway bar systems, Poly Control Arm Bushing and sleeve system, Spherical Control Arm Bearing system, lowering springs, performance struts and our strut braces as well as some cool and innovative solutions.
Sway Bars
Poly Control Arm Bushings
Spherical Bearings
We have all of these components in various packages that are designed with your specific needs in mind. We're taking pre-orders now so please feel free to call or email us anytime with questions or to find your closest Preferred Pfadt Dealer and Installer.
Kind regards,
Old 06-05-2009, 05:04 PM   #2
SS 376
SS 376's Avatar
Drives: IBM 1SS
Hey do you guys have a track C5 Z06? I was driving my wife to who knows where when I saw a red circuit-prepped C5 Z06 with a Pfadt sticker on it being trailered somewhere.
SS 376 is offline   Reply With Quote
Old 06-05-2009, 05:06 PM   #3
blackedout010
Drives: on order black 2010 2ss
get we get some pricing info??
blackedout010 is offline   Reply With Quote
Old 06-05-2009, 06:24 PM   #4
SoloSK71
SoloSK71's Avatar
Drives: 2010 Camaro 2SS
If it is anything like the Corvette kit, probably around $2k, $1k, $0.4k , $2k something like that?
- SK
SoloSK71 is offline   Reply With Quote
Old 06-07-2009, 02:51 PM   #5
Popy's VT
Popy's VT's Avatar
Drives: 2007 Corvette Coupe
You Camaro guys will love the quality of Pfadts goodies! I had no idea you were engineering stuff for the Camaro's Jordan. My best friend has a 2SS / RS on order and he's going to love hearing this news! He's ridden in my car many times and knows first hand the improvement your coilovers made for me!
Paul Cervone; 2007 AO MN6 Z51 Coupe BBP Vortex Rammer CAI, SpinPorted TB & Intake, JetHot Coated LG Pro Longtubes, Corsa Sports, MGW Short Shifter, EE Tunnel Plate, Oil Catch Can, Lowered, Tinted, GM Racing Spoiler, Tail & Side Marker Blackouts, Pfadt Coilovers, Michelin PS2's, 395 rwhp; 387 rwt
Popy's VT is offline   Reply With Quote
Old 06-08-2009, 01:45 PM   #6
PfadtRacing
Hi Can-Am,
We run a 99' C5 Coupe in NASA's ST1 class but we don't have a C5 Z06 that we personally race. We do however have a contingency program with NASA and decals are required; HERE is more information.
Please feel free to call or email us anytime!
Kind regards,
Old 06-08-2009, 01:50 PM   #7
PfadtRacing
Hi blackedout010,
We're still finalizing the pricing on our Camaro products; I should have it finished by next week. I will do another post with all of our Camaro products including pricing. Please feel free to call or email us anytime with product or set up questions. We appreciate your interest in Pfadt products and have a great day!
Kind regards,
Old 06-08-2009, 02:13 PM   #8
PfadtRacing
Hi Paul,
We appreciate the kind remarks!!!!! We're glad you're enjoying your Vette! We're really excited to release our 2010 Camaro line!
Kind regards,
Old 06-11-2009, 06:50 PM   #9
21STCENTURYMUSCLECARS
21STCENTURYMUSCLECARS's Avatar
Drives: 2010 SS RS Silver Ice 6-sp
PFADT
Hi Jordan, those look great!!
We have sold the PFADT products for the Corvette for quite some time and
they are awesome products and great people to do business with.
We will surely have these on our new 2010 shop car in the near future.
Best Regards,
John Page
Twenty First Century Muscle Cars
21STCENTURYMUSCLECARS is offline   Reply With Quote
Old 06-11-2009, 06:58 PM   #10
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Pfadt stuff is awesome. I've seen and felt it on a lot of C5/6s.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 06-16-2009, 09:48 AM   #11
PfadtRacing
Best Regards,
John Page
Hi John! Thanks!!! We have a lot of development time in these products and we're extremely excited about the Zeta platform!!
How is everything! We appreciate the kind remarks!!
We'll let you know when we get our production units on the shelf!
Kind regards,
Old 06-16-2009, 09:49 AM   #12
PfadtRacing
Old 06-16-2009, 10:27 AM   #13
WILWAXU
Drives: 2007 TBSS
Send a message via AIM to WILWAXU Send a message via Yahoo to WILWAXU
Great looking stuff!
John Brown
My FQuick Garage
WILWAXU is offline   Reply With Quote
Old 06-17-2009, 12:03 PM   #14
PfadtRacing
Pfadt Coil Over Pricing
We finally have our Introductory Pricing finished for the 2010 Pfadt Camaro Coil Over System!
Here is an overview that outlines the advantages of our Inverted Coil Over System:
1. Mono Tube Design
2. Inverted for less unsprung mass and increased Strut Strength
4. Adjuster is on the bottom of the shock and no tools or lifting are required to make damping adjustments; including detents so you can match damping
8. Engineered specifically for the Camaro and no other applications
Sale Price $2250
We're expecting to have our production batch in the next 6-8 Weeks. We've already received pre-orders from Dealers as well as customers. Pre-Order today and make sure you get the Pfadt Coil Overs as soon as we assemble them! The Deposit is $500.
Please feel free to call or email us anytime! We appreciate everyone's interest in Pfadt products and have a great day.
Kind regards,
Old 06-17-2009, 12:05 PM   #15
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Jordan -
One question - Are these the same ones that have been race proven in the Corvette or did you make some specific changes for the Camaro ? (other than mounting)
Thanks.
Old 06-17-2009, 12:22 PM   #16
PfadtRacing
Jordan -
Thanks.
Speedster,
The Pfadt Camaro Coil Overs were designed specifically for the 2010 Camaro. We used some of our Internal Damping technology but everything was developed for the Camaro. A lot of the time companies will take a Product from another application that is close and they will adapt it; we don't feel this is a good approach as every application is unique to some degree.
Please let me know if you have any further questions. We appreciate your interest in Pfadt products and have a great day!
Kind regards,
Old 03-29-2011, 09:10 PM   #17
rdm33rd
rdm33rd
Drives: Summit White w/ Black hockey stripe
Are these coilovers specifically for the SS or do they work on the v6 also?
Can you raise the ride height with these and if so how much?
rdm33rd is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 297 04-21-2013 05:38 PM
2010 Camaro PEDDERS EXTREME XA COIL OVERS ON HENNESSEY CAMARO! Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 75 06-20-2009 03:32 PM
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 12:14 PM
