BORLA
Old 11-08-2012, 11:02 AM   #1
SoCalCamaro93
SoCalCamaro93's Avatar
Drives: 2016 2SS
giive me a break
So the dealer didn't remove the spacers so I am getting them removed tomorrow. However, as I'm driving, twice, a loud thud type nnoice came from the front left wheel. Any explanations?
Past: 2011 RS, 2013 ZL1
Current: 2016 2SS
SoCalCamaro93 is offline   Reply With Quote
Old 11-08-2012, 11:10 AM   #2
starhutch
THE RED ROCKER
Drives: 2013 ZL1 VR
No clue, could be related to the front spacers being in....there are none in the rear. I would have it checked out when you bring it back in to the dealer.
starhutch is offline   Reply With Quote
Old 11-08-2012, 11:17 AM   #3
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 17 A10 ZL1,14 2ssrs,96,85,79,69&67
The spacer thing is not uncommon they did it to mine also.
Old 11-08-2012, 12:29 PM   #4
JWR046
JWR046's Avatar
Drives: 2012 ZL1 #1786
last I remember there was a sticker on window reminding the dealers to remove them.
Also in the PDI doc which they did not read. They needed to install a piece of the under belly guard in front of each front wheel so check that. You can find the PDI doc on the site somwhere.
JWR046 is offline   Reply With Quote
Old 11-08-2012, 09:22 PM   #5
SoCalCamaro93
Drives: 2016 2SS
So I took it to another dealer and they were in disbelief that the other dealer had failed to perform the proper final inspection and remove the spacers. They said no damage was done and the car should be fine. Thank goodness
Current: 2016 2SS
Old 11-08-2012, 09:35 PM   #6
trewyn15
trewyn15's Avatar
Drives: 2004 Monte Carlo LS
I would then take that to another dealer to confirm that no damage was done and the car will be fine. Seems like they may be trying to cover for the other dealer (if they were both GM dealers)
2004 Monte Carlo LS - 1966 AMC Rambler Rebel Classic - 2000 Trans Am WS6
trewyn15 is offline   Reply With Quote
Old 11-08-2012, 09:43 PM   #7
SoCalCamaro93
Drives: 2016 2SS
Yes, both GM dealers however, the dealer that took them out wrote down the dealers info and my cars information...maybe to report them?
Current: 2016 2SS
Old 11-08-2012, 09:49 PM   #8
SoCalCamaro93
Drives: 2016 2SS
Another thing that bugged me..the mechanics weren't giving me the spacers and kept saying, "when are you ever going to need them? You won't be towing this car" I had to argue with them in order to get the spacers back.
Current: 2016 2SS
Old 11-08-2012, 10:50 PM   #9
2ss-booya
2ss-booya's Avatar
Drives: 2015 SS Sedan M6
What dealer was this?
2ss-booya is offline   Reply With Quote
Old 11-08-2012, 10:59 PM   #10
wow, how can they be that careless, they should all know about the spacers by now.
Old 11-08-2012, 11:16 PM   #11
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
The PDI instructions state that the spacers are suppose to go in the glove box prior to delivery. If they were doing their job and read they would have done that.
And yes a lot of people right now put the car up on trailers. I do it all the time myself.
armysig is offline   Reply With Quote
Old 11-08-2012, 11:22 PM   #12
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
The owners manual says to use the spacers also, so they should be in the car.
Skylane765 is offline   Reply With Quote
