Old 11-08-2012, 07:25 PM   #1
Roto-fab 1
Roto-fab 1's Avatar
Drives: 16 Camaro SS w/ Roto-fab CAI
Introducing the "BIG GULP" !
The Roto-fab ZL1 CAI is making great power with or without a tune. Here's something to make it even better!
Introducing the BIG GULP! This duct is a bolt-in replacement for the stock air brake duct on the left side (driver's side) giving you much needed air to your intake while maintaining a brake duct! We've increased the inlet size to utilize more of the grill opening and we're making it adjustable! You have the option of routing all of the air to your air box or routing approximately the same air to your brake duct as stock, then the remainder to the air box. If you are drag racing or just want to go fast, go "all air box". If you are road racing, choose a position routing more air to the brakes.
Here's the stock left front brake cooling duct on the ZL1. For reference, the plastic inner fender bolts to the end of the duct with two screws (Note the W/W reservoir has been removed)
Here is the BIG GULP mounting in the same position.
Here is a view showing the air flow.
A comparison of the BIG GULP and the stock brake duct.
In this view you can see we have a larger entry than stock which allows us to use more of the grill opening.
Here is a top view showing the shape of the inner baffle and it's position in both extremities. The small silver circle is the hinge pin location.
Here is the adjusting lever in the recessed front grill area.
We have designed and molded this piece as a direct replacement for the stock duct. No drilling, cutting, etc., if you can change a tire you should have no problem installing it. The W/W reservoir does need to be relocated-we have a great kit for that as well!
Roto-fab 1 is offline   Reply With Quote
Old 11-08-2012, 08:09 PM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Do you have the rest of the ducting to the air filter area available too?
Also when are these available? I just ordered a cold air kit from you guys (through Jannetty) today.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 11-08-2012, 08:10 PM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
Awesome set up. We'll have to get these added to our site!
Juiced1 is offline   Reply With Quote
Old 11-08-2012, 09:11 PM   #4
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Awsome!!!!! When will they be avaliable for purchase?
Laus Deo
charlietuna is offline   Reply With Quote
Old 11-09-2012, 09:13 AM   #5
Roto-fab 1
Roto-fab 1's Avatar
The previous pics were taken with the inner fender taken out. Here is a top view pic taken with the inner fender in place. The camera is held where the filter normally sits. The inner fender itself, airbox and hood work together to isolate this area so no additional duct work is needed.
Jeremiah
Old 11-09-2012, 09:16 AM   #6
Roto-fab 1
Roto-fab 1's Avatar
We are still a few weeks out, but we will keep you guys updated with the progress!!
Jeremiah
Old 11-09-2012, 09:39 AM   #7
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
awesome!
Joe@CPR.com is offline   Reply With Quote
Old 11-09-2012, 10:44 AM   #8
DangerZL1
Drives: 2023 Black ZL1 Auto
Thanks for letting the cat out of the bag so to speak. I can see you put a lot of time into the design.
DangerZL1 is offline   Reply With Quote
Old 11-09-2012, 01:57 PM   #9
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
Nice
rpepka is offline   Reply With Quote
Old 11-12-2012, 05:02 PM   #10
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Jeremiah
Ahhh...I see now.
2012 ZL1
Old 11-24-2012, 08:48 AM   #11
ZL1ster
ZL1ster's Avatar
Drives: '13 ZL1 IOM M6
subscribing...
This too will make it into my zl1
Competitors are being left on the starting line
ZL1ster is offline   Reply With Quote
Old 11-27-2012, 10:36 AM   #12
Roto-fab 1
Roto-fab 1's Avatar
As promised, we did produce an informational video which also shows the highlights of installation. Here you go!
Mike
Old 11-27-2012, 08:14 PM   #13
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
One-Bad-ZL1 is offline   Reply With Quote
Old 12-21-2012, 02:43 PM   #14
ZL1ster
ZL1ster's Avatar
