B&M Racing
Old 11-09-2012, 11:05 AM   #1
CuSStomRS
CuSStomRS's Avatar
Drives: Black 2SSRS
Scratch in glass
I have a small scratch in the driver window. You can't feel it but you can definitely see it. Anyway to get it out?
CuSStomRS is offline   Reply With Quote
Old 11-09-2012, 11:41 AM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Do you have a Dual Action Buffer?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 11-09-2012, 02:02 PM   #3
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Typically you can't buff glass scratches out without a dedicated glass specific polish.
The stuff I've used in the past is a cerium oxide product that works with a bronze wool pad. Makes a HUGE mess and is pain to do, but its the best approach I've found to glass scratch correction.
Hitting it with a regular paint polish and polishing pad on a machine will sometimes make some improvement, but often times those products lack the cutting power needed to really correct glass.
If you don't have a machine its probably going to be a job to take to a pro b/c theres not going to be anything you can do by hand to make a big impact.
