BeckyD@RodgersChevrolet
Old 11-09-2012, 11:25 AM   #1
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
Lingenfelter 630 package... installed with dyno results. MTI Racing
I had the Lingenfelter 630 kit installed at MTI Racing in Marietta, GA. Attached is the dyno sheet. I notice that the baseline dyno was super low for a M6 car, however, the post-mod dyno is right where it should be. I have no explanation for the low dyno results initially
Mods include:
- 2.55 inch diameter steel supercharger drive pulley - powder coated black - 8 rib
- 8 rib serpentine belt
- Lingenfelter LS9 solid supercharger isolator coupling
- Port and polish supercharger snout
- Lingenfelter air intake duct
- K & N Air Filter
- 160 degree thermostat
- Increased boost level 10 - 12 psi or 3 - 4 psi over stock
- Professional engine modifications, testing & PCM tuning
- Chassis dyno report before & after installation
Jeff65SS is offline   Reply With Quote
Old 11-09-2012, 11:27 AM   #2
ace32x
Drives: 2013 ZL1
nice mods! a bet a bigger TB and heat exchanger would liven that up a bit more too
2013 victory red zl1, 2012 1500 silverado, 95 nissan 240sx 383 ls1 11:1 stroker dart 225 heads ms4 cam fast 102 manifold ;D
ace32x is offline   Reply With Quote
Old 11-09-2012, 11:50 AM   #3
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Those end results seem a little low for a manual, although you started pretty low. With your mods i would have expected close to 600rwhp and 580rwtq? At least from all the other post/dynos I have seen with similar mods. Some M6 are getting close to 530rwtq STOCK, although the average is around 505-510. Also, with a 2.55" UP, you should be close to 13psi of boost
69NMYSS is offline   Reply With Quote
Old 11-09-2012, 12:06 PM   #4
ace32x
Drives: 2013 ZL1
my guess is just dyno flucuations. cant imagine there being a 60 whp difference between bone stock cars XD
Old 11-09-2012, 12:15 PM   #5
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
Was thing an intake only pull?
KD Innovations is offline   Reply With Quote
Old 11-09-2012, 12:34 PM   #6
Jeff65SS
Jeff65SS's Avatar
Not that I am aware of.
