BORLA
Old 11-09-2012, 04:22 PM   #1
Bab515
Drives: Camaro 2LT
2013 Chevy Camaro Sunroof Problems
I'm unsure if I posted this is the right section, as I am new, but figured I would give it a shot. I bought a brand new 2013 camaro 2 lt about 3 weeks ago, and Im already having a problem with the sunroof. It was fine, up until today. After I close the sunroof, you can hear a gridning noise for about 8 seconds after, almost like its trying to keep closing, and it rattles now when going over a bump. I called the dealer and am going in, but I feel like theyre gonna say theres nothing they can do. help!!
Bab515 is offline   Reply With Quote
Old 11-09-2012, 04:30 PM   #2
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Why do you think they will tell you that?
Unless you have reasons to doubt their ability to fix the issue, I wouldn't worry about it.
Take it in and tell them exactly what you said in your post above.
I am sure they will get you fixed up. You already know it isn't normal, as it wasn't doing that when you first bought it.
So, give them a chance.
1996 Corvette - LT4
2017 Camaro 2SS
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 11-09-2012, 04:32 PM   #3
z28racer
z28racer's Avatar
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD
: sm0:
z28racer is offline   Reply With Quote
Old 11-09-2012, 04:43 PM   #4
NASCR3
NASCR3's Avatar
Drives: Synergy Green 2SS/RS/HURST
If it's a legit issue meaning it isn't one of those issues that "can't be duplicated" they'll just replace the entire sunroof module, or if it's easier then just the motor for the roof. If you question their ability to do the job then find a different dealer to take it to. Most dealers will have their body shop do these kind of jobs. Both of the dealers I used to work for had specific tech's for interior & trim work specifically.
2011 2SS/RS - Factory Hurst - Synergy Green - Cyber Gray Rally Stripes - Jet Black Interior - Born on 10/4/2010
2G1FT1EW7B9128807
Ordered: 8/6/2010
1100: 8/6/2010
2000: 8/23/2010
2051: 8/10/2010
2500: 8/24/2010
3000: 8/25/2010
3100: 9/8/2010
3300: 9/8/2010
3400: 9/11/2010
3800: 10/4/2010
4000: 10/4/2010
4200: 10/4/2010
5000: 10/13/2010
6000: 10/14/2010
NASCR3 is offline   Reply With Quote
Old 11-12-2012, 09:06 AM   #5
Chevrolet Customer Svc
Drives: GM Vehicles
Your dealership should be able to address this issue. It also sounds like you should be under warranty as well. The dealership will be able to check this for you also.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 11-12-2012, 12:05 PM   #6
RobShillington
Drives: 2012 Camaro 2SS/RS
Hey Bab515 - I had the same issue with the Sunroof (among many other issues) in my 2012 within the first month of buying the car. Took it to the Dealer where I purchased the vehicle and they stated the noise was normal and quoted it was "Body Flex" and I would just need to get used to it. After a litte research I decided to bring the car to another Chevy Dealer and without hesitation they called the sunroof defective and replaced the whole thing. Not an issue with the Sunroof since then.
RobShillington is offline   Reply With Quote
Old 12-12-2013, 08:10 AM   #7
Spc.Wilcox
Drives: 2013 Camaro 2LT RS
So many problems with my new 2013 Camaro 2 LT RS idk where to begin, my car has 5500 miles. I have been hearing squealing from my right rear tire, all four tire pressure sensors r showing completely wrong tire pressure light stays on, driver window squeals when going up, within 3500 miles I was 2 quarts low on oil. Now after an oil change, an 1k miles later the dip stick is showing oil on the notch second to the full notch without any leaks. Clutch jumps when I depress the clutch when coming to a stop, the noise is so loud that it can be heard from outside of the car in dash radio screen has a mind of its own n either comes on when I don't touch it or doesn't come on at all out freezes. The list goes on!!!!! Talked to the dealership where I bought it they said all of it is normal r u kidding
Spc.Wilcox is offline   Reply With Quote
Old 12-12-2013, 09:37 PM   #8
Drives: GM Vehicles
Spc.Wilcox,
Sorry to hear about these occurrences and I understand any frustration this causes. Would you like to try a second dealer? Feel free to message me privately (if you feel a second opinion is needed) and I'll reach out to the necessary dealer's customer care specialist who is the best solution to resolving customer issues at the dealer level.
William R.
Chevrolet Customer Care
Old 03-20-2014, 09:43 PM   #9
humblebeast07
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF
What was causing the rattle...my car is in the shop 3rd time in a week....same problem
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
humblebeast07 is offline   Reply With Quote
camaro, problems, sunroof
