Old 11-10-2012, 10:27 AM   #1
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
Talking STS Twin Turbo Upgrade
A local shop here is getting a line on STS Turbos. I was in his shop yesterday talking about upgrading the cam on my SS. He said why dont I just put a STS Twin Turbo in your car at his cost with free installation, so you can spank all these young guys who have NOS. But I'll have to show your car as a demo model for my shop. AHHHH, Yeah!! He's calling STS to get his price on the Twin Turbo version Monday. I'll post vids once the car is complete.
Who has a STS Twin Turbo? Comments please?
Thanks!!
Iroc2430 is offline   Reply With Quote
Old 11-10-2012, 01:38 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Check the FI section.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-10-2012, 01:39 PM   #3
Denis
Denis's Avatar
Drives: 2010 SS
yea try the FI section.....buuuuuuuuut at cost with free installation sounds like a killer deal.
Old 11-10-2012, 01:40 PM   #4
Birm
Birm's Avatar
Drives: Florida Speed & Power
Birm is offline   Reply With Quote
Old 11-10-2012, 01:51 PM   #5
Unreal
Drives: 2006 Z06
They could pay me to to install it, then I would pull it off and sell it to someone who didn't know better. I wouldn't touch that stuff with a 20ft stick IMO.
Nick
Corvette Z06 -1200ish rwhp
Old 11-10-2012, 02:30 PM   #6
uniqueskillz
uniqueskillz's Avatar
Drives: ETMC built 700+hp Twin Turbo LS3
exactly!! do a search about the STS kit before you pull the trigger. You never want the turbos that far away from the motor. (you'll get crazy lag)
uniqueskillz is offline   Reply With Quote
Old 11-10-2012, 02:34 PM   #7
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I was close to doing an STS kit, but then read about oiling issues and lag issues. That's when I ordered my maggie. There's a reason car manufacturers don't put turbos in the back of the car from the factory, it isn't the right way to do it. Trans mount, or engine mount is all you want with a turbo kit.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 11-10-2012, 02:41 PM   #8
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
I haven't read anything about lag or oiling issues. I will research this issue more before I pull the trigger. Thanks for all the input about the STS system. Please feel free to make any suggestion. Please keep the comments coming.
Thanks again everyone.
Old 11-10-2012, 02:54 PM   #9
Unreal
Drives: 2006 Z06
Buy anything but the STS. What do you want? There are tons of good kits out there that will make big power. ECS, Maggie, Whipple, IPS, Vortech, AGP, etc.
Nick
Old 11-10-2012, 04:29 PM   #10
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
I just spent 3 days cleaning up from an STS oiling issue. This was on my '01 Silverado. The power wire to the oil return pump cracked in half. The turbo overfilled with oil and blew +2 quarts of motor oil up thru the charge air pipes, intercooler, and into the engine.
After I soldered the broken power wire back together, I had to pull the turbo, all 17' of charge pipe, the intercooler, the throttle body, and the EGR valve. Oil everywhere. Had to soak the charge pipes for hours in hot soapy water, rinse and then spray them out with brake cleaner. I also spent 2 days repeatedly flushing the intercooler with hot soapy water until it finally flushed clean. Had to clean all the oil off the MAF sensor and the remote IAT sensor.
Put all the charge pipes back on along with the intercooler. Pullled the TB and cleaned it. Pulled the EGR as it was very oily and carboned up. Stuffed a shop rag into the intake manifold 3 times, pulling it out and it was an oily dripping mess. Ran a can of Sea Foam through it.
I used an entire bottle of dish soap, 4 cans of brake cleaner, 1 can of MAF cleaner, 1 can of TB cleaner, 1 can of Sea Foam, 3 rolls of paper towels, 1 package of shop rags, and about a half gallon of Fast Orange Hand Cleaner. What a PITA !!!
And this is a single turbo system. When you "oil down" a twin turbo setup, just double the effort I described above. PITA x2 !!!
Just got back from a 45 minute "aggresive" test drive and all seems well.
If I ever do another turbo setup, I'll be going with one that uses gravity feed to return the motor oil back to the engine sump. No more electric motors to pump the oil back for me.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 11-10-2012, 04:50 PM   #11
DZ302
Drives: 2010 2SS/RS LS3
Not true at all. I had STS divorced turbo on my Silverado. Absolutely ZERO lag. Made great power as soon as you touched the gas. 430HP/500TQ to the street through a 4l80e, a transfer case, 4.56:1 gears and 35" tires.
I have heard however that Squires no longer uses Garrett turbo's and instead is using cheap Chinese knock offs that do not last very long. Another word of warning is about the intake location. If you ever drive in heavy rain you will injest copious amounts of water vapor that will pool in your intake tubes. When you boost it will send all of this water across your MAF and the computer will read it as extremely dense air and dump fuel to match, essentially flooding your engine and leaving you roadside.
Night Furry2 cam, C.A.I. intake w/ Race Scoop and Washer Bottle Relocate Kit, Vmax T.B., LT's w/high flow cats, ATI Super Damper (10% UD), MGW STS w/retro ball.
DZ302 is offline   Reply With Quote
Old 11-10-2012, 05:18 PM   #12
14pilot
14pilot's Avatar
True. They come with cheap ass turbos and cheap ass hose clamps. I replaced my original turbo with a high quality american made ceramic ball bearing unit for a plus $2,000 cost. I ditched all the crappy worm drive hose clamps and replaced them stainless T-bolt clamp for another additional $150 cost.
So for the twin setup, upgrading both turbos to ceramic ball bearing units and replacing double the crappy hose clamps could run an additional $4,000.
Water ingestion: My truck is lifted 7 inches and being in Arizona, I've only sucked water in once. Left me by the road for about 30 minutes until it dried out enough to run. I 've about 122,000 miles on my STS system. The original STS turbo only lasted about 33K miles before it took a $4!t... I didn't go back to them for the replacement.
Old 11-10-2012, 05:48 PM   #13
DZ302
My truck was lifted 6" too. I stumbled upon a quick fix for water ingestion. If you flood out due to water on the MAF, simply unplug the MAF and away you go. I do not recommend boosting with the MAF sensor unplugged but you can drive for a short while carefully and it will dry off the sensor.
Old 11-10-2012, 06:27 PM   #14
14pilot
14pilot's Avatar
Great tip !!!
I've since switched to running in Speed Density Mode by unplugging the MAF.
Every 2 years when Emissions testing comes up, I plug the MAF connector back in, reset the code, and enable MIL reporting on the MAF.
I can do this because I put a divorced IAT sensor further down, between the Meth Injection Nozzle and the TB. With this setup I still have IATs.
