Old 11-10-2012, 02:50 PM   #1
BlackinBlack
BlackinBlack's Avatar
Drives: 2016 Corvette Z06 Blade Silver
Water spots and an easy fix
I have a black car and water spots are the bane of my existence.
Now living in FL in a house without a water softener I have noticed it is ten times worse. My car looked like crap and I was ready to take the car to a professional to have them fix it. I did a quick look on the internet and there was a recommendation to use 1:2 white vineger to water. So I thought WTH, I have nothing to lose. I bought a spray bottle mixed it up and gave it a try...... IT WORKS GREAT!!!
Total cost was $4 including a new spray bottle. If you have water spots this is the best fix I have found and will be a permanent addition to my detailing bag of tricks.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD>
Roto-Fab CAI
2010 2SS/RS BLACK on BLACK <SOLD>
3" MBRP 304 Stainless Exhaust
Roto-Fab CAI
BlackinBlack is offline   Reply With Quote
Old 11-10-2012, 03:57 PM   #2
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
i need before and after pictures please. and now your guys smells lol
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 11-10-2012, 04:07 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Yep very commonly used water spot remover. Glad you got the results you wanted.
*Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety*
[B]
Old 11-10-2012, 04:08 PM   #4
BlackinBlack
Wish I had done before and after. Car smelled like a salad but a little detailing spray fixed that up.
Next time I will take pictures.
Roto-Fab CAI
Roto-Fab CAI
Old 11-10-2012, 08:38 PM   #5
DangerZL1
Drives: Accord
I've read this works, so based on your post Il'll try it next time. My car is black too and spots suck. I use a gas blower to aid in drying. The last time my car spotted I used simple green to strip off the wax. Now I need to reapply.
DangerZL1 is offline   Reply With Quote
Old 11-10-2012, 08:54 PM   #6
BlackinBlack
Done the leaf blower thing too. Not sure if it helps or hurts as it blows the water dry on the car. The spots are smaller but there are a ton more of them. I have been using Zanio and tried everything to get the water spots off. Nothing seemed to work 100%. In bright sun you could see a shadow of the spots. It seems crazy to have to use a polish on the car everything I washed it. Washing in the shade helps but I don't have a great place to do that and there is always some hiding out. My car is a DD so getting caught in the rain guarantees spots. This was like magic. All the spots are 100% gone. I did put a fresh coat of Z5 on the car after I cleaned it. Not sure if this will strip the wax like Simple Green but a quick coat just to be sure.
Roto-Fab CAI
Roto-Fab CAI
Old 11-10-2012, 09:05 PM   #7
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I was told to use a leaf blower too as I was getting water spots. I went out and bought one and it made it even worse. I took a big drop of water and dispersed it into like 20 drops of water which evaporated much quicker causing even more water spots. Leaf blower doesn't work that well.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs, Tuned by Rhino79 at GPI.
rberns is offline   Reply With Quote
Old 11-10-2012, 11:07 PM   #8
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I use the leafblower to get water out of my crevices and under the emblems and mirrors.
I think the best thing to do OP and rberns is put on a few coats of wax and then start doing rinseless or waterless washes. They take less time for me and they never cause waterspots
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 11-11-2012, 08:11 AM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I use the Adams Master Baslter to blow it dry and then go over her with a detail spray from Mcguires.
Scott@Bjorn3D is offline   Reply With Quote
Old 11-11-2012, 08:24 AM   #10
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Drives: 2011 Camaro SS/RS
I do the same except use Adams DS. This removes the water spots except this last time as I waited 10 minutes or so to go over it with the DS. Sometimes I will use my Flex and Brilliant Glaze in place of DS.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS
BUILD
TIMING CHAIN FAILURE
TRANSITION FROM STOCK TO CAM VID
Maxspeed is offline   Reply With Quote
Old 11-11-2012, 09:43 AM   #11
Vikas2k
Drives: '12 Camaro LS V6 6MT, '01 Civic LX
Vinegar is acidic. Would this not remove the wax coating all together if applied (even its diluted half and half)?
Vikas2k is offline   Reply With Quote
Old 11-11-2012, 09:50 AM   #12
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
+1 great stuff
Fire Extinguisher, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, 275's all around, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms, Custom HP ZL1 Tune by Mark Romans
JewelSS is offline   Reply With Quote
