Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 06-05-2009, 04:45 PM   #1
Tecca
Tecca's Avatar
Drives: 2010 Camaro 2LT SIM/RJT
Painting the Engine Cover
I went to three paint shops today because I want to get my engine cover painted silver to match the exterior. All three places wouldn't touch it because they said the paint will peel off. Anyone know if this is true or have any other options???
Tecca is offline   Reply With Quote
Old 06-05-2009, 05:33 PM   #2
live2well
Drives: 2010 VR 2SS/RS A6
I've painted a few dodge engine covers...
-make sure you clean them real good with hot water and dish detergent to get off any grease and grim.
-lightly sand 1500-2000 grit sandpaper.
-use promotion adhesion spray, let it dry
-prime it with the proper color to cover the original color
-I use Krylon spray paint, cause of it being plastic.
make sure you get about 3-4 good coats of your color with ample drying inbetween coats
-I used automotive clear coat, about 6-7 coats of clear.
some people wet sand between clear coats
the heat from the engine has never caused an issue with using the Krylon paint, been done for about 2 years now on my dodge. Still a work in process.
Intelligence plus character that is the goal of true education.
BrianC. :flag2:
live2well is offline   Reply With Quote
Old 06-05-2009, 05:41 PM   #3
nards444
nards444's Avatar
Drives: 1SS/RS Black
it can be done the factory is having it done. But like all plastic being painted, in time it will wear off dont matter what you do
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 06-05-2009, 05:51 PM   #4
MadMaxx
Master of the V6
MadMaxx's Avatar
Drives: 2010 Camaro 1LT/RS
If you're using an adhesion promoter + primer layer, you aren't limited to a plastic (krylon fusion for example) paint. Plastic specific paint usually has a bonding agent and flex agent built in. This piece isn't flexing, and we've got a layer between the paint and the actual plastic surface...so it won't matter.
The biggest keys to success:
**ALL** oils need to come off!!! I can't stress that enough. After the initial wash and degrease, make sure all future contact to the part is done with latex gloves... the oil from your fingers can and will make a difference.
Adhesion promoter + good primer (if you sanded, use a light fill primer) is the best base you can get down.
Don't mix n' match paint types. Stick with the same brand where ever possible... been there, done that... not fun.
MadMaxx is offline   Reply With Quote
Old 06-05-2009, 11:36 PM   #5
Yellow2010
Yellow2010's Avatar
Drives: Rally Yellow 2SS 2010
I painted mine and it looks great. I am in no way a painting expert. They are right, make sure you clean the plastic really good before painting. I used plain rubbing alcohol, scrubed it good, and let dry for at least an hour before painting. Here is the results.
Yellow2010 is offline   Reply With Quote
Old 06-06-2009, 08:25 AM   #6
Chemical
Chemical's Avatar
Drives: 2SS RS
wow that looks good. How did you get a paint match? ^^
Chemical is offline   Reply With Quote
Old 06-06-2009, 02:16 PM   #7
Yellow2010
Yellow2010's Avatar
Luck really. I bought several cans of different paints and test painted some other plastic. It was the closes match.
Old 06-06-2009, 02:20 PM   #8
greg_74
greg_74's Avatar
Drives: 2002 Camaro SS
You could look into having it powdercoated with nobody will paint it and you don't want to. I know there are places that paint LS1, LS6, and Fast Intakes so I wouldn't see why they wouldn't do LS3 ones.
2002 Chevrolet Camaro SS #7590
345 HP Package, LPP Headers and ORY, GMMG, SLP CAI and Smooth Bellows, PHB, Chrome TTM's
greg_74 is offline   Reply With Quote
Old 06-15-2009, 08:58 AM   #9
efpardo
Deep6
efpardo's Avatar
Drives: 2010 Camaro# 8212 | 2LT | RS | CGM
Send a message via Skype™ to efpardo
I couldn't order my Cyber Gray Camaro with the Cyber Gray Engine cover so...
I Painted it myself
efpardo is offline   Reply With Quote
Old 06-17-2009, 08:21 AM   #10
1998 Brickyard
1998 Brickyard's Avatar
Drives: 2010 RS & 1998 Brickyard SS
I appreciate the fact that you spent the money buying several cans.
To save everyone else that expense, what brand and or color code was the can that you ultimately used?
1LT/RS, Rally Yellow, Black Interior, Auto, Convenience Pkg, Black Rally Stripes.
1100 2/26/09
2000 3/26/09
3000 3/26/09
3100 4/30/09
3300 4/30/09
3400 5/7/09
3800 5/14/09 - 2G1FB1EV3A9110149
4200 5/23/09
4800 6/2/09 Almost here...
5000 6/3/09
6000 6/4/09
1998 Brickyard is offline   Reply With Quote
Old 06-17-2009, 11:29 AM   #11
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 99 Camaro
I have had good luck with the SEM Color Clear paint in the rattle can and painting plastic. But, I have never put it under a high temperature (it did survive solar load though). I painted a rubber steering wheel with SEM and it stayed on for two years without chipping, it is even flexible. Also painted many interior trim pieces with no issues.
-Geoff
08 Silverado - No times yet.
99Z28 - 11.91@118.5. 403 with street tires and launching with the traction control.
SomeGeoffGuy is offline   Reply With Quote
Old 06-17-2009, 11:37 AM   #12
pinkcamaro10
pinkcamaro10's Avatar
Drives: 2010 Camaro
Send a message via MSN to pinkcamaro10 Send a message via Yahoo to pinkcamaro10
how much were you gonna pay to have it painted?
3300:4/30
3400:5/7
3800:5/14 2G1FC1EV1A9110079
4104:5/20
4200:5/30
delivered: 6/9/2009
pinkcamaro10 is offline   Reply With Quote
Old 06-17-2009, 11:47 AM   #13
Tecca
Tecca's Avatar
Well the guy that ended up putting my RJT stripes on is going to paint it. Although he is charging $175 it is going to be SIM with some RJT accent stripes as well. Plus he won't get started on it until nextweeks. I know I can do it cheaper if I did it myself but the guy is real good and $175 is that bad since he is doing a two tone paint job.
Old 06-17-2009, 11:50 AM   #14
pinkcamaro10
Drives: 2010 Camaro
I see, I was just curious. After we see how things go with my engine cover, i was gonna see if anyone else wanted theirs done so i can make some spare money..
3300:4/30
3400:5/7
4104:5/20
4200:5/30
delivered: 6/9/2009
Old 06-21-2009, 07:45 PM   #15
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Hay. Yellow2010. What brand of paint did ypu end up using? you all did some great work there. OUTSTANDING>
cowboy1948 is offline   Reply With Quote
Old 06-21-2009, 09:47 PM   #16
KJS
4 years old May 2013
KJS's Avatar
Drives: '10 in RJT; 95 Vette
Didn't realize there was a thread on this already....here's my two cents....
http://www.camaro5.com/forums/showthread.php?t=28651
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 06-24-2009, 07:06 PM   #17
Yellow2010
Yellow2010's Avatar
To save you some expense here is the color and type paint I used for painting the engine cover. Dupli-Color (HIGH PERFORMANCE) Caliper Paint (Yellow BCP 101).
Roadtrip in Victory Red Camaro SS w/ cloth interior! (Captured Test Fleet Car) HeatherR Camaro Photos | Spyshots | Video | Media Gallery 930 08-31-2010 10:21 AM
engine cover smike07 Cosmetics and Lighting Modification Discussions 36 11-05-2008 08:26 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
