Jason 98 TA
Old 11-11-2012, 06:04 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Winter Storage: Possible fix to flat spots on tires
I went to Home Depot today and picked up some EPS Insulation. It is very dense foam board. It cost around 6 bucks and came in 6 sheets. Each sheet is 3/4 inch thick and 4 feet long. I stacked three of them together and cut them in half. In addition, I put a piece of thick carpeting I had laying around on top. I put 40 psi in the tires and drove the rear up. The front I jacked up and lowered onto the foam. We will see if this does a good job come spring time.
newagemuscle is offline   Reply With Quote
Old 11-11-2012, 06:52 PM   #2
TAPSHIFT
TAPSHIFT's Avatar
Drives: '11 IBM 2SS/RS '16 1GB Z51 ragtop
Winter storage
That is the same method I use for my Vettes and Hotrod for winter parking/storage (the Camaro is a daily driver-winter included).
It is, however, a good idea to lay plastic down to keep moisture from coming up from the concrete slab to the car's chassis.
TAPSHIFT is offline   Reply With Quote
Old 11-11-2012, 06:55 PM   #3
newagemuscle
Philippians 4:13
It is, however, a good idea to lay plastic down to keep moisture from coming up from the concrete slab to the car's chasis.
You know I saw a picture of someone doing that and was wondering why they had it under the car. Good Idea. I need to move the car out next week anyway. I will do that. Thanks
Old 11-11-2012, 07:05 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Maybe it's me or the pic but your car look like you had to remove the mirror to get it that close to the wall. Also that look like a good ideal.
Sent from my iPad using Tapatalk HD
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 11-11-2012, 07:06 PM   #5
hunterv6
Always bet on Black
hunterv6's Avatar
Old 11-11-2012, 07:06 PM   #6
newagemuscle
Philippians 4:13
Maybe it's me or the pic but your car look like you had to remove the mirror to get it that close to the fall. Also that look like a good ideal.
No, but it probably 1 inch away.
Old 11-11-2012, 07:08 PM   #7
hunterv6
Always bet on Black
hunterv6's Avatar
Bet that wasn't easy
Old 11-12-2012, 07:10 PM   #8
kissmyss03
kissmyss03's Avatar
Drives: 2011 Camaro SS 2SS/RS
looks good! i just put mine away yesteday and put a small peice of carpet under each tire. good idea on the foam, ill have to do that for next year
2011 Camaro 2SS/RS M6
Kooks Headers, catless mids, corsa exhaust, rotofab intake, SLP TVS 2300, 3.2 pulley, blower cam, cts-v fuel pump, Vector tuned 622 RWHP 573 TQ
kissmyss03 is offline   Reply With Quote
Old 11-13-2012, 10:27 AM   #9
newagemuscle
Philippians 4:13
Love your cover
