Flowmaster Exhaust
Old 06-05-2009, 06:59 PM   #1
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Add tilt sensor to GM alarm?
Does anyone know what is needed and how to install a tilt sensor into the factory alarm?
Parts/wiring?
patriotpa is offline   Reply With Quote
Old 06-23-2009, 04:27 PM   #2
The Viz
The Viz's Avatar
Drives: Everything
I believe they have one available through GM accessories. They do for every other vehicle.
The Viz is offline   Reply With Quote
Old 07-15-2009, 07:16 PM   #3
bluman
bluman's Avatar
Drives: '10 Corvette GS/'13 Mustang
Yes it can be done (I did it) it's wired thru the trunk pin, ran into problems trying to connect it to the hood pin, they told me it wasn't drawing enough current to trigger the alarm
Digital Tilt Sensor made by VIPER total cost $90
2010 Camaro SIM/CGM RS/2LT VIN #310 SOLD
2010 Corvette Grand Sport
bluman is offline   Reply With Quote
Old 08-08-2009, 07:50 AM   #4
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
How did you connect it ? in series or parallel w/ trunk pin ?
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 08-09-2009, 02:16 PM   #5
69er
Drives: 69 Z/28 , 83 Z/28 (L69), 10 2SS CGM
It needs to be in series. If they are in parallel, then both switches would have to be closed to trigger the alarm. In series, either one will trigger it.
69er is offline   Reply With Quote
Old 08-09-2009, 02:27 PM   #6
patriotpa
It needs to be PARALLEL.
Ex:
Series:----SWITCH--------Tilt sensor-------- BOTH have to be closed to alarm.
PARALLEL: I-------SWITCH------I
PARALLEL: I-------Tilt Sensor---I EITHER will create alarm.
Old 08-09-2009, 03:23 PM   #7
69er
Ex:
My bad, I was looking at it backwards. If either switch was to OPEN when triggered, then it would have to be in series. Since they CLOSE when triggered, then either switch will trigger the alarm.
Old 08-09-2009, 06:31 PM   #8
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
Would this be for setting your alarm off if someone tows your car away?
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 08-09-2009, 07:38 PM   #9
Silverguardrail
Thanx !
Alarm in a box Vash Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 05-31-2009 11:10 PM
Aftermarket Performance Items to Add? bevot9 5th Gen Camaro SS LS LT General Discussions 6 05-02-2009 08:49 PM
