Solo Performance
Old 11-12-2012, 06:04 PM   #1
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
1LE shafts and hubs ordered
how much hp u guys think they will hold , im hopin they will handle my 460rwhp and a 125 shot
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-12-2012, 06:25 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
What i heard is it is the same one as the mighty ZL1 so should be pretty strong,as well- the supercharger and magnetic ride this is a ZL1
cornerspeed92 is offline   Reply With Quote
Old 11-12-2012, 06:32 PM   #3
Synner
Drives: 2011 2SS/RS M6
Post some comparison pics next to the stockers when they arrive. I'm curious how much difference there is, bearing size, axle size, etc.
Without wheel hop you should be fine until you grenade your pumpkin. Kinda depends on your tire and transmission combo if that'll happen.
Old 11-13-2012, 11:03 AM   #4
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
1LE half shafts are not the ZL1 half shafts. The wheel hubs however are and have beefed up bearings to handling more load when cornering, not just for HP. Did you order 2 for the rear or 4? Both the ZL1 and 1LE have new hubs on all four wheels, not just the rears.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 11-14-2012, 03:54 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
2 dont need 4, only changing rears .
the axel are diff from the ss , cause our axels wont work , but they are indeed diff then the zl1 too.
i think its got the same size or teeth on the diff side as the ss , but the hub size is the same teeth as the zl1. but they are bigger
so basically the the le1 is a zl1 axel that will fit the ss pumpkin. the zl1 has a beefed up pumpkin aswell..
Old 11-17-2012, 11:04 PM   #6
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
well went to put these in and u need the axel nut aswell its diff size then the ss, but they seem to be a lil thicker like a 1/8 or 3/16 and the cv boots are bigger aswell.
got pics will load later
Old 11-17-2012, 11:10 PM   #7
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Would you mind posting up all the parts you needed for this? Thanks. Sounds like the axle nut and cv boots at the very least.
bannonm is offline   Reply With Quote
Old 11-17-2012, 11:19 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Thanks for sharing OP, want pics and more detail!
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 11-18-2012, 06:48 AM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i been taking pics as i go but hubs / axels and the axel nut is all thats needed i think. will find out next go around
Old 11-18-2012, 12:10 PM   #10
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Why didn't you just get the zl1 shafts and hubs? You know what those will hold and they seem to be beefier than the 1LE (the shafts, not the hubs).
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 11-18-2012, 12:13 PM   #11
nak3dsnake
nak3dsnake's Avatar
Because he'd have to buy the Zl1 rear diff too, which is over a grand. ZL1 half shafts will not work the the SS,1LE diff.
Old 11-18-2012, 02:53 PM   #12
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
......Oh wait....THERE ARE NONE!!!
Come on Dekan, show us some pictures of these axles and hubs....you're killin' me here!!! Also, what's the part number on those hubs? I've found two different part numbers, and I don't know which is correct.
blazzin1 is offline   Reply With Quote
Old 11-18-2012, 02:57 PM   #13
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Please post up the info/site and part numbers for these if you don't mind.
CHMSC is offline   Reply With Quote
Old 11-18-2012, 08:16 PM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
photos
