SDPC
Old 11-18-2012, 08:38 PM   #15
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
ill get better pic next go around , and try to find something to measure with , its hard to tell the diff in pics but there is a lil diff tho, they have to be a lil stronger , how much i dont know but ill put them to the test , should be 625rwhp and around 700+ rwtq , if they handle that then we know they r ok lol.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-18-2012, 09:23 PM   #16
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Hmmm, weird, not what I expected! I don't hardly see much difference at all. Certainly not beefed up like the ZL1 axles. Well, they certainly can't be any worse!!! Give 'em hell and let's see how they do!!! Thanks for the pictures man.
blazzin1 is offline   Reply With Quote
Old 11-19-2012, 07:05 AM   #17
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
the splines are the biggest diff , and from what i can tell with a messuring gauge i got that only messures 2 - 3 inches it shows a 1/8 to 3/16 diff in thickness in the center of the axel the boots are bigger too.
Old 11-19-2012, 08:29 AM   #18
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I'm willing to bet you can install the rear "HD" 1LE bearing/hubs with the older SS axles, I don't GM would change the spline count nor spline diameter, the new bearing are most likely just wider.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 11-19-2012, 11:45 AM   #19
blazzin1
blazzin1's Avatar
Hey dekan, what part number are those hubs?
Old 11-19-2012, 01:23 PM   #20
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Ed M.
That's what I think as well, but no one has yet to get a set untill now.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 11-19-2012, 03:21 PM   #21
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
if what u r sayin is the le1 axel will go in the ss hubs , its a no i tried just to see ,wont do it lol
Old 11-19-2012, 03:22 PM   #22
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
and on part numbers i just looked at them le1 parts thread
Old 11-19-2012, 03:25 PM   #23
nak3dsnake
nak3dsnake's Avatar
what about the half shaft nut part number?
Old 11-19-2012, 03:38 PM   #24
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
http://www.camaro5.com/forums/showthread.php?t=237956
here is theinfo i used. i acually had a friend order but he use this page tho.
Old 11-19-2012, 03:38 PM   #25
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
does anyone know where the axels are breakin at like in tthe cv boots , the center bar the splines . just wondering
Old 11-19-2012, 04:10 PM   #26
blazzin1
blazzin1's Avatar
See that's the problem....the link you posted says the part number for the Hubs is 22924741. However, this other link (below) from "nak3dsnake", says the part number for the Hubs is 25954415. I'm trying to figure out who is correct???? Can someone please verify???? And yes, a part number on the axle nut would be nice too (you would think that would have come with the F'n axle!!!) if someone can find it!!! Thanks.
http://www.camaro5.com/forums/showthread.php?t=244570
Old 11-19-2012, 04:15 PM   #27
nak3dsnake
nak3dsnake's Avatar
My part number is from a dealerships parts database. I can show you the sheet if you would like.
Old 11-19-2012, 04:18 PM   #28
blazzin1
blazzin1's Avatar
Originally Posted by nak3dsnake View Post
My part number is from a dealerships parts catalog. I can show you the sheet if you would like.
I believe you, I just want to find out why there are two different part numbers!?!?!? And if dekan ordered the other part number, did he order and/or receive the wrong hubs? Can you show the sheet you were looking at, does it specify 1LE? Just curious man, not trying to "call you out" or anything!!!
