Old 11-14-2012, 03:22 AM   #1
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Arrow 1LE Delivery Day Checklist
This will be the third Camaro I have had in the last 18 months. I have learned a lot from this site and from first hand experience. So after I have made sure the dealership does NOT wash the car or fill it up with 87 octane...
I am going to install the catch can, a designated clutch reservoir and do a quick brake fluid flush. Can't forget the all important fuse pull. Then I am going to begin the break in.
The delivery day will end with me going all Junkman on itz ass.
Day two I hope to be able to start turning some wrenches.
tramtwo is offline   Reply With Quote
Old 11-14-2012, 04:03 AM   #2
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Say more about NOT washing it.
CrystalRedTintcoat is offline   Reply With Quote
Old 11-14-2012, 04:38 AM   #3
CrystalRedTintcoat
Not following the fuse issue. Break in tips are really interesting. Watching junk man videos now. Like his energy.
Old 11-14-2012, 12:27 PM   #4
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
DISO
The fuse issue is basically this. If there is low octane fuel used the car the computer will switch to a different programming which causes reduced performance. The only way to get the car to switch back to the higher octane or optimal performance programming is to do what is affectionately called a "fuse pull" around here.
The fuse pull resets the computer, which will begin to relearn as you drive.
Old 11-14-2012, 02:43 PM   #5
Soulr che
Soulr che's Avatar
Drives: 2lt Camaro
great link. read and saved for future reference!
Soulr che is offline   Reply With Quote
Old 11-14-2012, 03:52 PM   #6
MF2SSRS
Drives: VR 1LE
Originally Posted by tramtwo View Post
DISO
I thought the fuse pull was only necessary for the L99.
MF2SSRS is offline   Reply With Quote
Old 11-14-2012, 05:24 PM   #7
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
For both versions of the engine and also the zl1 guys are benefiting from it as well.
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel.
Old 11-14-2012, 05:34 PM   #8
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Witch fuse do you pull?
cornerspeed92 is offline   Reply With Quote
Old 11-14-2012, 05:36 PM   #9
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
It is number 5 and 20 on my 2011 LS3. I leave them out over night.
Old 11-14-2012, 06:09 PM   #10
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
I read through your thread about the water problems with your convertible. I'm glad things worked out for you and you are going to receive a 1LE. I don't think I'd wish what you went through on my worst enemy!!! Definitely post pics when you have it home.
Big C CamaroSS is offline   Reply With Quote
Old 11-14-2012, 06:15 PM   #11
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Thank you. I will.
Old 11-15-2012, 12:42 AM   #12
CrystalRedTintcoat
Tram: can you post the link to your water damage issues referenced above by Big C?
Old 11-15-2012, 01:16 AM   #13
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
It is a long story.
Old 11-18-2012, 06:38 AM   #14
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
I think you need to repeat the part about them not touching the paint. I have a strange feeling that some high school hack can't wait to jack up your new paint job.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
