Caryle Racing
Old 11-14-2012, 03:50 PM   #1
Soulr che
Soulr che's Avatar
Drives: 2lt Camaro
Question on Dealer Invoice - Dual Exhaust
does the following description mean it has or doesnt have dual exhaust?
Engine, 6.2L V8 SFI (426 hp [317.6 kW] @ 5900 rpm, 420 lb-ft of torque [567.0 N-m] @ 4600 rpm) (Requires (MN6) 6-speed manual transmission.) (STD)
Transmission, 6-speed manual (STD)
Axle, 3.45 ratio
Differential, limited slip
Rear wheel drive
Alternator, 150 amps
Battery, maintenance-free with rundown protection and retained accessory power
Suspension, Performance
Steering, power, variable ratio, electric
Brakes, 4-wheel antilock, 4-wheel disc (Brembo performance 4 piston front and 4 piston rear brakes.)
Brakes, Brembo
Exhaust, dual-outlet stainless-steel with polished tips
its incoming to a dealership near me. its a 2ss with rs and 1le package.
thanks in advance.
Soulr che is offline   Reply With Quote
Old 11-14-2012, 03:54 PM   #2
LRJet35
LRJet35's Avatar
Drives: 2013 2SS RS 1LE
Looks like it has the standard dual exhaust, not the dual mode performance exhaust.
It also says 3.45 ratio, the 1LE comes with a 3.91 final drive ratio....
LRJet35 is offline   Reply With Quote
Old 11-14-2012, 03:56 PM   #3
Soulr che
Soulr che's Avatar
Drives: 2lt Camaro
thats what i read it to mean also. great they added the nav package but not the reason for a v8...and didnt catch the ratio.
thanks!
Old 11-14-2012, 03:59 PM   #4
LRJet35
LRJet35's Avatar
Exactly...to me the NPP exhaust would be a must have on these cars unless you're planning on putting your own aftermarket system on...
Old 11-14-2012, 07:05 PM   #5
MF2SSRS
Drives: VR 1LE
Is it me or does it not look like they added the 1LE package? My invoice looks a lot different.
MF2SSRS is offline   Reply With Quote
Old 11-14-2012, 07:20 PM   #6
rmyers
rmyers's Avatar
Drives: Both American Made
Get the VIN and look up the window sticker online.
2012 ZL1 #213 M6 Black on Black
2013 ZL1 #2638 Convertible Auto
2010 Chevrolet Suburban
2011 GMC Seirra HD Denali
rmyers is offline   Reply With Quote
Old 11-14-2012, 07:40 PM   #7
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Don't see RPO code NPP mentioned so I would say no, it doesn't have it
Old 11-14-2012, 07:44 PM   #8
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
It comes stock with the 1LE package"dual port exhaust" the "dual mode" is the key word.
cornerspeed92 is offline   Reply With Quote
Old 11-14-2012, 11:03 PM   #9
beany323
beany323's Avatar
Drives: Camaro 2SS /RS/1LE
i'll see if i can find that. you (ok maybe you guys can) cant imagine how many times i build a car.. sheeshh.. change color.. add rs lights.. remove them.. do i need a 200 watt stero initially.. .lol.. i'll see what i can find and thanks again.
99% this is it:
2G1FT1EW4D9161086
dont recall where to locate it. i know it was here somewhere..
beany323 is offline   Reply With Quote
Old 11-15-2012, 11:03 AM   #10
BillyD
Drives: Turbo Toaster
It's in Riverside and does not have the NPP exhaust..
99% this is it:
2G1FT1EW4D9161086
BillyD is offline   Reply With Quote
Old 11-15-2012, 11:35 AM   #11
Soulr che
Soulr che's Avatar
Drives: 2lt Camaro
thanks. and i am seeing alot of those in my area. if i may ask where did you go to find that info out? (or is it you have to kill me if you tell me) (then if you would be so kind, tell my ex-wife )
thanks again!
