Old 11-15-2012, 02:14 PM   #15
Enough
Drives: 2013ZL1
Originally Posted by JWR046 View Post
So if you added the no tune CAI and a 90mm TB would you need a tune? I assume yes with all the extra air flow
The MAF is reading airflow and should compensate without a tune.
Enough is offline   Reply With Quote
Old 11-15-2012, 02:18 PM   #16
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Was talking in pm to Ted this morning and he said we wouldn't be able to run a bigger tb with our a tune after all ):
ace32x is offline   Reply With Quote
Old 11-15-2012, 08:40 PM   #17
hognutz
hognutz's Avatar
Drives: 2013 ZL1
he stated in another thread that the TB and cold air together would require tune. just the TB alone though has been doen without tune.
I want pulley, cai, tb so I will have to tune.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 11-15-2012, 08:53 PM   #18
ace32x
ace32x's Avatar
Drives: 2013 ZL1
I have the cai already so that would require a tune then. Thinking of doing the 9.1" and put some torco in
Old 11-16-2012, 10:27 AM   #19
usmcjlp
Drives: 2SS/RS LS3 RJT
ace32x,
The 102 has had some driveability issues I believe. The 90 is OEM reliability.
usmcjlp is offline   Reply With Quote
Old 11-16-2012, 11:01 AM   #20
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Originally Posted by usmcjlp View Post
ace32x,
i have a 102 on my stroked ls1 in my 240sx and have never had a problem with it
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
Old 11-22-2012, 06:58 AM   #21
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
We have proved time and time again with valid data that anything above 10psi the stock TB becomes a major restriction and anything above 13psi the requirement of a 102mm TB is really necessary to prevent major airflow restrictions. The 102mm TB is worth about 2psi from 3700rpm and up at the 600-650+RWHP mark translating in much higher HP and a broader power curve
We keep these in stock in BLACK or Natural
We have zero driveability issues with the cars we tune, but many adjustments need to be made for this TB. The throttle response alone is worth it
Meister@Torq is offline   Reply With Quote
Old 11-22-2012, 10:11 AM   #22
SC2150
The 90 works great IF tuned for it....but it is not a plug and play.
The 87mm VMax CNC patteren ported makes a very noticable difference though and that is a direct swap.
Old 11-29-2012, 10:41 PM   #23
BLACK10
BLACK10's Avatar
Yep, you CAN NOT just swap the tb and go with it. It has to be tuned properly. Although many do mods and don't tune, which IMHO, is not getting your monies worth out of the parts.
Old 11-30-2012, 10:58 AM   #24
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Originally Posted by ace32x View Post
thats what i was thinking aswell. i dont want to buy 2 TBs tho which is why im leaning twords a 102, but on the other hand i dont want to pull the snout off yet either. Wondering what the gains would be with a 102 with a stock snout
nothing
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 11-30-2012, 11:01 AM   #25
ace32x
ace32x's Avatar
Drives: 2013 ZL1
Originally Posted by 2012ZL1 View Post
nothing
weve gathered that now. going to port the snout and pick up a 102 and tune it here in the spring. running a roto fab a 9.1" pulley and torco currently, will be good enough until i can get some LT's test pipes the TB and ported snout and tune it
Old 12-25-2012, 04:39 PM   #26
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
good point. I am definitely getting a no tune CAI. I will probably get a pully but do not want to tune the car yet. JRE has some great results. I am thinking the CAI and 90MM TB to start and then can add pulley etc with or without a tune when I want. Still want to retain the factory warrentee at this point. A CAI and TB is a pretty cheap upgrade which can be utilized with any future mods.
I am ramming Rotofab CAI and going with 5% OD pulley and no tune. I do not see how the pulley and TB will still maintain warranty, so I will be ready to reinstall OEM.
As far as I can see, only CC and CAI will not void warranty, OD the SC and then have it go bad will not fly for warranty.
Skylane765 is offline   Reply With Quote
Old 12-25-2012, 08:22 PM   #27
Garys16SS
Garys16SS's Avatar
Drives: 2016 SS, BLACK, MANUAL
I am having a memory lapse but what does the CC stand for??
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come.
Garys16SS is offline   Reply With Quote
Old 12-25-2012, 08:51 PM   #28
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Catch can I think
'17 ZL1 A10 Mosaic Black PDR/Nav 2:07.59 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
