Emblempros
Old 12-28-2012, 06:08 PM   #29
Garys16SS
Garys16SS's Avatar
Drives: 2016 SS, BLACK, MANUAL
Originally Posted by Stephen12ZL1 View Post
Catch can I think
Thanks, you are correct!!
2016 Black/Black SS, 6speed, MRC, Roto-Fab air intake, Vitesse controller,
1 7/8" headers and exhaust from Stainless Works complete with nonNPP mufflers and 5"outlets, Katech ported TB, Moroso catch can, MRR M017 polished powder wheels, Eibach lowering springs, and BMR upper/ lower trailing arms and upper control arms. ZL1/1le sway bars and Magnusson Supercharger with Jannetty tune. Stay Tuned!!!......More to come.
Garys16SS is offline   Reply With Quote
Old 01-09-2013, 10:20 PM   #30
KerrDogg
KerrDogg's Avatar
Drives: 2013 ZL1
SO ???
Ive purchased the rotofab cold air and 90 mm GM TB
Will it need a tune or not ?????
KerrDogg is offline   Reply With Quote
Old 01-15-2013, 10:55 AM   #31
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
Originally Posted by ace32x View Post
car is currently stock. but im throwing a rotafab intake on my m6 zl1 as soon as i recieve it and was wondering if the stock throttle body had any gains to be had by replacing it with a nw 102? for now im not modding to heavily but down the road i will be doing a cam and valve springs and heat exchanger/pump and headers so it will eventually be needed.
was just curious if the money was worth it now to pick one up to combo with the intake
It only flows about 1180 CFM but respoonds very well to porting. Anohter 170 CFM or so can be attined with a good port job. The bottom of hte throttle blade is pretty shrouded.
KD Innovations is offline   Reply With Quote
Old 01-15-2013, 12:42 PM   #32
ace32x
ace32x's Avatar
Drives: 2013 ZL1
i ended up buying a 102, need to port the snout now. i also need a heat exchanger but i havent seen anyone making one for the zl1 yet except for cooler logic
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 01-15-2013, 08:41 PM   #33
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
KDI makes an HX too. I have the cooler logic unit which is very nice.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-15-2013, 08:57 PM   #34
Makinrain
Drives: 2012 ZL1
I did the 102NW and had KDi do their complete blower and snout porting. Also went with their HX as well. The porting on the blower was extremely well done and the HX is VERY nice piece to say the least. Highly recommend both.
Makinrain is offline   Reply With Quote
Old 01-15-2013, 09:09 PM   #35
ace32x
ace32x's Avatar
Drives: 2013 ZL1
what all do they port on the blower? i need to get my snout ported still but i havent looked into the blower yet. i bought theyre Heat exchanger today aswell
Old 01-15-2013, 09:45 PM   #36
Makinrain
Drives: 2012 ZL1
They open the snout all the way up to the 102 opening and then do a real nice transition into the blower housing. As far as the blower itself. You would have to see it truthfully. There is no area left untouched in the housing area. When Keith was explaining it to me over the phone I didn't appreciate the amount of work that was going into it until I got it back. But once you do a before and after its pretty amazing. You won't be disappointed.
Old 02-05-2013, 01:22 AM   #37
gkviper192
gkviper192's Avatar
Drives: TBSS
Originally Posted by rpepka View Post
What TB does the ZR1 Corvette have?
87mm
gkviper192 is offline   Reply With Quote
Old 02-18-2013, 03:24 PM   #38
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
off topic but I don't know why the heck GM didn't put a 90mm TB on the ZL1, CTS-V or ZR1 when they had the parts already from the LS7 which has been around since 2006. GM must've known these S/C cars get modded and the 90mm TB would've been a better baseline to start with.
My Toys:
2012 ZL1 Coupe (M6) #80
2012 Nissan Titan
2007 Ducati 1098
2006 Yamaha R6 (Track/Race Only )
IcePick06 is offline   Reply With Quote
Old 02-18-2013, 03:56 PM   #39
RedDragon
RedDragon's Avatar
Drives: 1967 Camaro and SIM 2013 ZL1
At what size TB do you need to port the snout? Has anyone used a 95mm TB yet?
RedDragon is offline   Reply With Quote
Old 02-22-2013, 10:42 AM   #40
gkviper192
gkviper192's Avatar
Drives: TBSS
the snout is 87mm, so with any throttle body larger than that, porting the snout would be necessary.
Old 02-22-2013, 04:18 PM   #41
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I though the snout was 90mm. I have 90mm no porting on the snout.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 02-25-2013, 02:55 PM   #42
gkviper192
gkviper192's Avatar
Drives: TBSS
maybe the back of the 87 and 90 are the same diameter? I assumed the 90 would be larger.
If you reach your fingers in and feel the transition between the throttle body and the snout is it smooth?
