Emblempros
Old 11-14-2012, 04:41 PM   #1
Travo
Travo's Avatar
Drives: 2010 CGM 2LT/RS
Check engine light P0449 on and off
I recently just had the CEL come on with a p0449 code: Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction. I was planning on taking to the dealer Tuesday but after being on for about a day and a half the CEL turned off. I'm curious if the CEL turning off after being on means that the problem doesn't exist anymore? I thought maybe the 2 straight weeks of rain from Hurricane Sandy could have caused some electrical problem to show this error then maybe turned off when it was completely dry. I would much rather skip the 500 dollar repair if there is no major problem. Any help at all would be greatly appreciated, thanks!
I also had this problem about 6 months ago the code was P0306:Cylinder 6 Misfire Detected. The CEL also turned off after about 10 minutes of being lit, so I end up ignoring it.
Travo is offline   Reply With Quote
Old 11-21-2012, 11:53 PM   #2
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
I also have this CEL code and would like to bump this. I have cats/tune, and am wondering how to fix it as well....
AAC Amber Halo's///LSR Short Throw Shifter///BMR Front & Rear Sway Bars///BMR Lowering Springs///Airaid CAI///BBK Headers & Mid-Pipes///Borla Exhaust///Martin Smallwood Custom Cam w/ Support Mods///Tick Performance Dyno Tune///Port&Polished LS3 Heads///Elite Engineering Catch Can///Gen5DIY Separate Clutch Reservoir///Harwood 5" Cowl Induction Hood
Cornflakes'Camaro is offline   Reply With Quote
Old 11-22-2012, 10:17 AM   #3
SC2150
Check your gas cap first, but may be the solinoid. Time to go to the dealer if emmissions related like this.
Old 11-22-2012, 12:35 PM   #4
Travo
Travo's Avatar
The light came back on the other day do I took it to the dealer yesterday. They told me I needed a new purge canister. They were trying to charge $710 with labor, but made a quick call to GM Chevy assistance and they talked with the dealer. They bumped it down to 100 plus tax for the replacement plus labor.
Seems as if this is a problem for a lot of the 2010-2011 models. Probably why GM has helped out with the price, I would recommend going that route if you have the same issue.
Old 11-22-2012, 03:37 PM   #5
Cornflakes'Camaro
I have headers w/ mid pipes...is the CEL because of the mods? Should I even go to the dealer if I don't have Cat's anymore?
Old 11-22-2012, 06:59 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Nope.
P0449 only has two known causes. Loose gas cap, or bad purge canister/solenoid.
If it's the canister or solenoid check Autozone or Advance before you go to the dealer. We recently had the same issue on my dads '03 Impala. The dealer wanted $300 to replace it. I went to Autozone and got the part for $35 and changed it in less then 5 mins.
Old 11-22-2012, 07:05 PM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Sure enough found the part for the Camaro on Autozone for $28. http://www.autozone.com/autozone/par...ifier=396_0_0_
I don't know exactly where it's at on the Camaro but it's located somewhere near the gas tank.
Old 11-23-2012, 01:11 AM   #8
Cornflakes'Camaro
Originally Posted by Mr_Draco View Post
Nope.
Mr. Draco you're the man. I'll look into it and post my results!
Old 11-23-2012, 01:32 AM   #9
Travo
Travo's Avatar
This isn't the correct part, the part number should be 92226690. Its around $178 at retail, sadly not $28. I saw on amazon they are going for around 80 though, so might be able to get one cheaper there.
Old 11-23-2012, 04:08 PM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The number you posted is the GM part number. My dad's impala was the same way. I took it off and went to the dealer to buy one and the retail on one from GM was $200. I walked out and went to Autozone and they had it for $35. When our issue first arisen I googled "2003 Impala P0449" and there was a lot of sites saying the same thing, that the GM part number was really expansive and they was able to get one at Autozone or Advanced for $30-$40.
Old 05-08-2013, 09:23 PM   #11
bambino87
Drives: 2010 rs
what number did you call?
bambino87 is offline   Reply With Quote
Old 05-09-2013, 12:26 AM   #12
Travo
Travo's Avatar
Look up GM Chevy Assistance
