Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 11-14-2012, 08:12 PM   #1
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: an 8 second Camaro
Lingenfelter RPM Limiter Timing Retard Launch Controller LNC-2000
I am going with a Big Stuff 3 for my new build, so I will no longer be needing this. The item is new & still in the sealed plastic bag. Thanks...
$200 Shipped
From the Lingenfelter website
Sometimes referred to as a 2-step or launch controller, the LNC-2000 adjustable RPM limiter and timing retard controller can be used to provide consistent launch RPM off the line in drag racing and other standing start racing applications. In turbocharged applications the LNC-2000 can also be used to retard the timing in order to build more boost at the line.
The LNC-2000 can also be used as an adjustable individual cylinder RPM limiter, providing reliable and fast acting spark based engine RPM limit control. This is especially useful in vehicles that have auxiliary fuel control systems where it is not possible to make sure that both the factory ECM/PCM and the auxiliary systems both turn off fuel at exactly the same time. If the two don’t completely cut fuel at the same time you will run lean when the one system cuts off the injectors, risking severe engine damage.
The Timing Retard capabilities of the LNC-2000 can be used to retard timing by up to 15 degrees. For nitrous oxide applications the timing retard can be activated using the dedicated timing retard activation input to the LNC-2000. In turbocharged and supercharged engines the amount of retard can be controlled by the boost level using the 3 bar MAP sensor input. The LNC-2000 can also be used to retard the timing at the line to build boost in turbocharged vehicle applications with or without the launch control RPM active. The Timing Retard function can be used by itself or while the Launch Control RPM limit function is active.
Please note - although launch controllers like the LNC-2000 are often referred to as 2-step controllers, they are not true 2-step controllers. A 2-step has a high and a low RPM limit function with a switch of some type enabling one setting or the other. The LNC-2000 only has one RPM limit setting so if you are using the LNC-2000 as a launch control RPM limiter, you will need to use the factory ECM/PCM as the engine maximum RPM limiter engine speed governor.
The RPM limiter function of the LNC-2000 acts by disabling spark to individual cylinders and not fuel like most production RPM limiters so the 2-Step/Launch Control function is not meant for use on the street or for use on cars equipped with catalytic converters. The 2-Step/Launch Control function of the LNC-2000 is only for use at the race track on race vehicles not equipped with catalysts. Failure to follow these precautions can result in premature catalyst failure.
DO NOT operate the engine with the LNC-2000 RPM limit active for extended periods of time. Due to the raw fuel in the exhaust when the RPM limit is active, a risk of backfiring exists if you do so.
A TVS diode is required with the use of any solenoid like NOS, Linelock or trans brakes when installing the Lingenfelter Launch controllers on your vehicle to prevent fly-back voltage levels at times seen in excess of 600 volts. LNC-2000 includes 3 TVS Noise Suppression Diodes if you have multiple relays you will need to buy one for each relay.
Name:  LNC-2000 (450 x 600).jpg
BrainleSS is offline   Reply With Quote
Old 11-14-2012, 09:07 PM   #2
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
lol, i just bought one like 16 hours ago , 300 bucks shipped this would have been nice
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-14-2012, 09:12 PM   #3
BrainleSS
BrainleSS's Avatar
Return it and save $60 bucks.
Old 11-17-2012, 06:02 PM   #4
Birm
Birm's Avatar
Drives: Florida Speed & Power
Is this turbo specific or good for sc too as I am undecided on which fi at the moment
Birm is offline   Reply With Quote
Old 11-17-2012, 06:05 PM   #5
BrainleSS
BrainleSS's Avatar
It can be used with either, but it's main purpose is to pull timing for nitrous applications.
Old 12-20-2012, 09:03 AM   #6
RonniesCamaroSS
RonniesCamaroSS's Avatar
Drives: 2011 SS camaro
Do you still have this
RonniesCamaroSS is offline   Reply With Quote
Old 12-20-2012, 01:04 PM   #7
BrainleSS
BrainleSS's Avatar
Old 01-26-2013, 08:50 PM   #8
BrainleSS
BrainleSS's Avatar
Back up for sale Member never paid
Old 01-26-2013, 09:37 PM   #9
BrainleSS
BrainleSS's Avatar
Sold again, no for real this time! Thanks Kev
