Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 11-17-2012, 03:46 PM   #1
BIGBLKZL1
BIGBLKZL1's Avatar
Drives: '12 ZL1/M6
Cleaning Black Wheels
I used Simple Green to spray (heavily) inside the wheels where the brake dust was really thick. It sat for about 2 or 3 minutes and then I hosed it off then repeated it. Worked great getting all the brake dust off.
Anyone find something else that works well? I could still use something better for the outside of the wheel in between the full cleanings.
BIGBLKZL1 is offline   Reply With Quote
Old 11-17-2012, 04:03 PM   #2
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
Are the ZL1 wheels clear coated? If so, you'll want to treat them like you do your paint. There are places where you can get good product to keep them clean. I would suggest Adam's Green Wheel cleaner. It works wonders.
Frid is offline   Reply With Quote
Old 11-17-2012, 04:11 PM   #3
Neriah
Neriah's Avatar
Drives: 2011 2SS/RS
Built By Blu808
LG G6X3 Cam, UD Pully, Rotofab Intake.
Dynatech LT's. Borla ATAK Catback.
Full BMR bushings and suspension.
Neriah is offline   Reply With Quote
Old 11-17-2012, 08:05 PM   #4
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
I wouldn't use Simple Green on the clear coated wheels. I use a set of Wheel Woolies with same shampoo I use on the paint. They allow you to clean behind the spokes and in between the spokes, behind the brake caliper, as well as inside and outside rims.
They make a set of three Wheel Woolies that come in different sizes and it takes all three sizes to clean the polished ZL1 wheels and they work great. Awesome product highly recommended.
You can get them at Adams or any good detailing store on line.
zfuzz is offline   Reply With Quote
Old 11-18-2012, 01:09 PM   #5
Errnie-ZL1
2013 ZL1 blk on blk
Drives: Time to order mods well she sleeps!
And company called Swissvax makes a good wheel wax to prevent dust build up.
Errnie-ZL1 is offline   Reply With Quote
Old 11-18-2012, 02:06 PM   #6
Kmax
Kmax's Avatar
Drives: 2012 ZL1 125HP kit , EIBACH springs
I've used Simple Green as we'll and works fine. I just dilute the strength with water, 1/4 Simple Green to 3/4 water, Then wax them.
Kmax is offline   Reply With Quote
Old 11-18-2012, 03:48 PM   #7
ZL1LEGEND
ZL1 - The Legend Returns!
ZL1LEGEND's Avatar
Drives: 2013 ZL1 Camaro
http://www.rizencreative.com/blog/wp...spitfamily.jpg
Pig Spit works great for in between cleanings. Takes break dust off, shines them up and actually repels dust pretty well also.
ZL1LEGEND is offline   Reply With Quote
Old 11-19-2012, 06:50 PM   #8
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
I use Mother's all wheel cleaner and it works great. I used it on my 2010 SS with the polished wheels and it worked great on them too. Just spray on all of them even on the inside and rinse off,. Works even better if you have a pressure washer, I use just a small one and that way I can clean up under the fenderwells also.
KLR ZL1 is offline   Reply With Quote
Old 11-19-2012, 06:54 PM   #9
trewyn15
trewyn15's Avatar
Drives: 2004 Monte Carlo LS
Personally I have used Meguiars spray quick wax after just cleaning the wheels, it keeps them nice and shiny and is an easy way to wax the wheels
2004 Monte Carlo LS - 1966 AMC Rambler Rebel Classic - 2000 Trans Am WS6
trewyn15 is offline   Reply With Quote
Old 11-19-2012, 08:38 PM   #10
OldScoolCamaro
...break dust is a major issue after a relatively short amount of time operating the car....no doubt....it's a hassle. I'm staying away from cleaners that can etch and compromise the paint surface since it's not anything durable or resilient to defend against potentially harsh chemicals no matter what the consumer thinks or manufacturer suggests over time. Simple green is still a strong agent no matter how much you cut it...
Old 11-20-2012, 07:19 AM   #11
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
gblaue is offline   Reply With Quote
Old 11-20-2012, 07:24 AM   #12
JWR046
JWR046's Avatar
Drives: 2012 ZL1 #1786
I have always used eagle one wheel cleaner. I use it sparingly and on wet cool wheels. I have used it on my 95 z28 and they are still perfect.
JWR046 is offline   Reply With Quote
Old 11-20-2012, 08:02 AM   #13
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
I took mine off when I first got the car and put a few coats of Zaino on them. It at least keep the dust from sticking.
Whenever I have the car on the lift (oil change or anything else). I take the wheels off, clean them good and put another coat on.
It's impossible to really keep them clean all the time.
Happy_Dan is offline   Reply With Quote
Old 11-20-2012, 08:22 AM   #14
dorfmac
www.macsautodetail.com
dorfmac's Avatar
Drives: 2010 2LT/RS
Your best bet on wheels is just to use soap and water. Anything else, over time, could result in damage to the finish.
dorfmac is offline   Reply With Quote
