sjm autoprod
Old 11-18-2012, 05:55 PM   #1
MzCamaro
MzCamaro's Avatar
Drives: 2012 Camaro 2SS / RS Coupe
Stock GM paint protector issue
Hello All,
I was doing a detailed wash on my Camaro SS this afternoon and I noticed what appears to be dirt under the material that is supposed to block paint chips (or at least that's what I assume it's there for) on the bottom of my passenger side door frame. Now, I never knew if GM installed it or my dealer. I ASSUME it's GM since I bought the car brand new from a Chevy dealer. Anyway, I was wondering if anyone else had this issue of trapped dirt. It's noticeable and I'm not sure what to do about it..
All suggestions are welcome. Photos are below:
PROBLEM AREA (PASSENGER SIDE):
WHAT THE OTHER (DRIVER'S) SIDE LOOKS LIKE:
Rally Yellow 2012 2SS Coupe, Sunroof, Automatic Trans, Polished 20" Rims, RS package..... Mods coming soon!
MzCamaro is offline   Reply With Quote
Old 11-18-2012, 07:21 PM   #2
intensifi
Drives: '12 2LT Convertible
It's a factory item.
I had a body shop quote $46 to replace a black one.
Try the dealer first.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 11-18-2012, 07:45 PM   #3
CooG
RIP - Convertible SS
CooG's Avatar
Drives: '13 Mustang Boss 302 - RED
Black one? I'm pretty sure it's just clear vinyl.
My passenger side doesn't have dirt under it, but it is beginning to peel a bit. Looks like it has an air bubble under it.
If you are REALLY worried about it, order some clear 3M vinyl....pull the old one off (carefully), trace the old one on the new vinyl, cut it out and reinstall. You may need a hairdryer to help get it to conform.
I'm guessing you could get a local vinyl shop to give you a few scraps pieces of clear....and bat your eyes a bit and they may even install it! I'm sure someone from a local car club would help you as well....
CooG is offline   Reply With Quote
Old 11-18-2012, 07:59 PM   #4
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
I had the same problem and just peeled them off. Came off without effort. I didn't replace mine, kind of a joke for protection if you ask me. Here was my post on this:
http://www.camaro5.com/forums/showthread.php?t=141886
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
Old 11-18-2012, 08:19 PM   #5
MzCamaro
MzCamaro's Avatar
Thanks everyone! I'm scared to peel them off myself... will the paint underneath come off too? Eek.
Old 11-18-2012, 08:25 PM   #6
CooG
CooG's Avatar
Naaa...paint will be fine. Use a little elbow grease, rubbing alcohol or GooGone (if needed) to get any sticky stuff off.
Old 11-18-2012, 08:49 PM   #7
Ocikat
Ocikat's Avatar
Drives: 2012 2LT 45th convertible
a bit of heat from a hair dryer will help with removal also, just be careful if your using goo gone or something similar as it's flamable
Top Ten Reasons I Procrastinate
1.
Ocikat is offline   Reply With Quote
Old 11-18-2012, 08:50 PM   #8
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
I pulled those off within a day or so of delivery.
babytiger is offline   Reply With Quote
Old 11-19-2012, 06:41 PM   #9
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Thats to protect the car during shipping, its just clear vinyl no were as thick as real paint protection.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 11-19-2012, 07:00 PM   #10
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
That's not entirely correct. They are intended to be protective for the life of the car.
Mine has a little dirt in it also. I'll replace them with OEM when I get tired of them. Those are high-impact locations, and it wouldn't take much to chip those areas.
Bye bye, Bumblebee!
