| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
I noticed that the forum has very knowledgeable people. A lot of people are talking about adding aftermarket performance parts for more rwhp. My question is if someone knows if it will affect the factory warranty? Will it be void because of this or only void for what work has been done? I want to put in an exhaust system because I was rearended and the exhaust will have to be replaced anyway. Anyone know?
Driving: 2010 2LT/RS, Silver Ice Met: The only reason I love going and leaving work!!!
ss
Drives: all black ss Join Date: Dec 2008
im asked this question a few days back and i aswell recieved no responses.
![]() Drives: 2010 Camaro SS / 2011 Z28 Join Date: Jun 2008
There are some mods that simply void the warranty for that portion of the car. For instance if you modify exhaust then clearly GM will not cover any exhaust related issues. But if you had some other problem then you would be fine. As long as the failure is not linked to the modification you have made there is no issue. Now with guys that start cracking open the engines they open to door to all kinds of issues. As to the exhaust question you have, if you want it covered under warranty you should replace it with the factory system. Generally the insurance company will do this.
![]() ![]() ![]() ![]() ![]() ![]() Drives: IBM 1SS Join Date: Feb 2009
If you search, you'll find some threads on modifications and warranty. Long story short, if you replace an OEM part with an aftermarket part like an exhaust, your warranty wouldn't apply as to that part. But if there is a failure, the dealer would be obligated to do repair work under warranty unless the aftermarket part caused the failure. That is per the Magnuson-Moss Warranty Act. Here is a useful link:
http://www.dummies.com/how-to/conten...ty-intact.html |
![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 92 300zx 2001 Ram Join Date: Feb 2009
but u better know your stuff cuz they will try to tell you that ur aftermarket mod caused the problem...so you have to prove otherwise
unless its blatanly obvious that it didnt...
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Now in your case, if you really care about the warranty related to your exhaust, I would A) contact your dealer first and tell them what happened and get a list of GM approved exhaust (if there is one) and any advise they may have B) have it replaced by one of the approved exhaust systems C) keep ALL documentation including info on the wreak and damage to the exhaust, advise from your dealer, info on the exhaust that you put on along with when and who installed it. |
#7 | |
![]() Drives: Soon-to-be 1st Gen Join Date: Nov 2008
Remember, YOU must prove that the mods did not cause the problem. I have been told by lawyers, who have fought on behalf of the customer, that the Magnuson-Moss Warranty Act is not worth the paper on which it's printed. |
#8 |
Thanks guys that makes all good sense and is what I was kind of assuming. Like if the starter has issues it would not be related to the exhaust change over and should be covered still. Thank you for replying.
#9 |
Geek
Drives: IOM 2010 Camaro 2SS Join Date: Oct 2008
#10 |
Hello!
#11 |
![]() Drives: 12 SS 45th Join Date: Oct 2008
It also depends on how good of terms you are on with your dealer. My 95 Z had aftermarket heads and a cam in it and I developed an intake leak I think it was, and I had them do it under warranty! The mechanic pulled the intake off and WHOA, look at these ports!LOL
Got the itch for a Camaro again....Itch is now scratched...2012 45th SS LS3
#12 | |
4 years old May 2013
Drives: '10 in RJT; 95 Vette Join Date: Feb 2009
http://www.camaro5.com/forums/showthread.php?t=25427
"As ye sow, so shall ye reap" - Me
Mine at sunset |
#13 |
well if you get performance mods from the dealer than it good. But usually it will just void that specific part, but a lot times if covered by the aftermarket company. Now heres an example. They will void the warranty for everything behind something in the system. So lets say you get exhaust theres nothing behind it in the system so they will just not cover your exhaust. But if you get headers then everything behind that will not be covered so your cats, exahust. If you did a charger well then the whole motor. But like others have said they have to prove that it did it. But they would probably have an easier time proving it then you trying to disprove it.
My opinion, if I do mods they will be GM performance parts at the dealer while I have the warranty. Now once its up then i am thinking about doing a charger. Plus wait till i got the car paid off and its mine, i just dont think its the smartest thing to dump a bunch of money into something you dont own.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
#14 |
![]() Drives: #5 Tom Henry Racing 2010 2SS/RS Join Date: May 2009
Please correct me if I'm wrong...I went to Indy last September and sat in the seminar with almost everyone connected to the Camaro at that seminar. I remember someone saying that if you had GMPP parts used in your mod and, if it was installed by a certified GM mechanic at a GM dealership it would not affect the warranty at all.
#15 | |
From 2 door to 5 door
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum Join Date: Apr 2009
So if you have not got your car yet, and want GMPP parts, get them put on by the dealer before you buy so you can benifit from the full warranty.
![]() '01 Pewter Corvette Convertible 6spd - Traded in on... '10 CGM SS RS Ordered- DELIVERED! - Traded in on... '06 Blk Crystal Pearl Magnum SRT-8 At least now my car won't be sitting in the garage every time the family goes somewhere. 3200 miles driven in 16 months was just pathetic. |
| Thread Tools | |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 79 | 03-04-2013 09:25 AM |
| Aftermarket Custom Mirrors (concept camaro style) ? | AMERICANMADE | Cosmetics and Lighting Modification Discussions | 1 | 06-03-2009 01:30 PM |
| SMS Camaro to be produced (by Steve Saleen) | Sizzox | 5th Gen Camaro SS LS LT General Discussions | 165 | 01-08-2009 02:11 PM |
