Emblempros
Old 11-20-2012, 05:40 AM   #1
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
SCT data logging question?
Can you use the SCT data logging to "record" runs and look back at them?
maybe on a graph?
I would be interested in seeing the data from throttle position, torque management,RPM, vehicle speed...these kind of things.
Also what is the sample rate of the data logger?
is it adjustable?
If not, can someone guide me in the right direction.
I have a Gtech Fanatic and it isnt the most accurate device i've used...and wont record mire than 30 seconds.
Thanks.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 11-20-2012, 08:20 AM   #2
jbrown13
jbrown13's Avatar
Drives: 2011 Camaro SS L99
Yes. You need Live Link software (free on SCT site) and a laptop. You can choose from a long list of items to log to narrow down what you want to see. Instructions, etc. on SCT site.
Jeff
jbrown13 is offline   Reply With Quote
Old 11-20-2012, 09:29 AM   #3
dcoates18481
cool...sounds good
I LIKE TO GO FAST!
Old 11-20-2012, 11:51 AM   #4
dcoates18481
Anyone have a list of parameters you can log with it?
I LIKE TO GO FAST!
Old 11-20-2012, 01:14 PM   #5
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Jeff
You forgot to add, Good luck getting it to work.
Nitroman28 is offline   Reply With Quote
Old 11-20-2012, 01:29 PM   #6
dcoates18481
yours wont work? that sux
I LIKE TO GO FAST!
Old 11-20-2012, 01:59 PM   #7
Nitroman28
Nitroman28's Avatar
I had it working fine, Then I upgraded laptops after my old one went out, and cant get it to work on the new one. It connects and I can select what i want logged, then it says cant get info. Old computer was XP, New one is Vista, that maybe the problem.
Old 11-20-2012, 02:12 PM   #8
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
Originally Posted by Nitroman28 View Post
I had it working fine, Then I upgraded laptops after my old one went out, and cant get it to work on the new one. It connects and I can select what i want logged, then it say cant get info. Old computer was XP new on is Vista, that may be the problem.
Doubt it.. I run a windows 8 laptop and haven't had issues.
Be sure to run the newest versions of both the live link Gen 2 software, and the SCT Device updater.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 11-20-2012, 05:16 PM   #9
jbrown13
jbrown13's Avatar
My Windows 7 laptop worked fine with the Live Link II software and SCT X3 tuner.
Do the updates that Scotty suggests and it should work fine. The Live Link software guides you through the process step-by-step.
I logged for a JRE tune and he had me log 12 different things: Accel pedal position; Engine coolant temp; Fuel pressure; Ignition timing advance; Inlet air temp; Inlet manifold absolute pressure; Knock retard; Long term fuel trim bank 1; ditto bank 2; MAF frequency; RPM; and Vehicle speed.
Jeff
Old 11-20-2012, 06:13 PM   #10
dcoates18481
Awesome thanks!
I LIKE TO GO FAST!
Old 11-20-2012, 06:15 PM   #11
Nitroman28
Nitroman28's Avatar
Jeff
Tried to use it a few weeks back and no updates, Tried it after you posted that and there was an update for it, works now.
Old 11-21-2012, 05:21 AM   #12
dcoates18481
list of all the parameters that can be logged?
I LIKE TO GO FAST!
Old 11-21-2012, 05:57 AM   #13
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
My 2010 SS/A6 reports about 190 pids. I dont recall anyway to dump the list of available pids. The earlier post mentioned 12 pids that are the most valuable when logging.
One thing to be aware of is my SCT never reports anything meaningful about fuel pressure pids. So as an alternative, I bought a dashdaq and use it for logging. It's not for the technically challenged nor is it cheap. But it logs fuel pressure. It is also self contained, so no need to keep a laptop connected while tracking the car.
Southern Comfort is offline   Reply With Quote
Old 11-21-2012, 06:42 AM   #14
dcoates18481
Good enough for me.
I just need to see the things you would most want to see during a high speed run.
Torque/ HP wound be nice to have!
I have the Gtech SS Fanatic, but it lies....Badly!! and only records for 30 seconds....
I LIKE TO GO FAST!
