Rick@Livernois
Old 12-08-2012, 04:44 PM   #29
MA2010SS
Drives: 2010 Camaro SS
Originally Posted by BLKSS1LE View Post
I just got back from a week in Italy for work and started my camaro and after about 30 seconds I tried to put it into reverse and it wouldnt let me go in reverse now! It feels like it doesnt have a reverse. I then went to 1st and 2nd notchy of course and went back to reverse. It then poped out of gear while I was trying to back up.... I decided just going to drive it for another 500 miles or so till I get it broke in better.... who knows. Seams like I got the only lemon!
I worked on a 4gen camaro a few years back and it had the same issue you are having, the solinoid for the 1-4 skip shift was partially stuck causing that particular cars issue, it never fully returned giving it a very notchy 1-2 up and 3-2 down. I would have the dealer look into that solinoid. Let us know what they find
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, Tuned by SLOWHAWK Performance Bridgewater MA 577RWHP
MA2010SS is offline   Reply With Quote
Old 12-08-2012, 04:59 PM   #30
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
You have to have it serviced. The shifting on this car is way better with the zl1 short throw than the hurst.
tramtwo is offline   Reply With Quote
Old 12-08-2012, 05:55 PM   #31
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Your going to have to try and take it to another dealer. Sounds like a bad trans to me. Best thing to try is bleeding the hydraulics frist and see if that helps.
IDEALG is offline   Reply With Quote
Old 12-08-2012, 08:42 PM   #32
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Not sure if this will help,but i bought the skip shift eliminator from Phastek performance(like $27.00)even before i got my car,im not a mechanic,and it took me 5 min.to install it,and now i can shift whenever i want.
cornerspeed92 is offline   Reply With Quote
Old 12-08-2012, 08:47 PM   #33
2ssx2
2ssx2's Avatar
Drives: 2013 2ss se/ 2009 cobalt ss
Do you really need skip shift eliminator or can a tuner dial it out.?
2ssx2 is offline   Reply With Quote
Old 12-08-2012, 09:55 PM   #34
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
If you tune it CAN be eliminated.
Old 12-08-2012, 10:06 PM   #35
cornerspeed92
Any tune what so ever, will void you're warranty. Once you touch the mapping of the car you cant go back.
Old 12-08-2012, 10:07 PM   #36
LikaRokBowTie
Drives: Harley Davidson Street Glide
I just got to test drive one and had no problem with shifting and I have not driven a manual in 11 years so my shifting wasn't the smoothest,so that was on me,but I never had the skip shift engage and no grinding,a blast to drive.I think I'll be ordering around April for a June delivery.So hope you can get that checked out and fixed if there is a problem
LikaRokBowTie is offline   Reply With Quote
Old 12-09-2012, 10:09 AM   #37
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 2014 SS sedan
These transmissions for the most part (up to 700RWHP) are bullet proof. The o.p. might just have a bad trans...its happens from time to time...you have almost your full warranty left...the sky isn't falling. Any COMPETENT service department will be able to fix your issue.
2014 SS Sedan-"houston stock" granny sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 12-09-2012, 10:21 AM   #38
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
My 577WHP 1LE was "built" @ 1600 miles with zero issues.....and with 600+ more miles since the build.....still zero issues. Oh yeah.....and 4 passes at the track. Almost sounds like a crap shoot wether you have issues or not but seems fairly rare.
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 12-11-2012, 06:08 PM   #39
tslsa28
Drives: 1991 with 383 and Mini Ram
I'm new to Camaro5.com but have raced a thirdgen Camaro for years with a Tremec 3550 and now a TKO. My Tremecs didn't shift very well until I used GM transmission fluid for a 2008 ZO6. It shifts at over 6000 rpm with this fluid and I didn't realize how much of a difference the right fluid could make. If that doesn't work, the transmission can be rebuilt with carbon synchros.
tslsa28 is offline   Reply With Quote
Old 12-14-2012, 02:40 AM   #40
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
My car shifts VERY nicely especially when the RPMs are higher than 2K. I do have a couple complaints, however.
1. When the skip shift comes on and, thus, forces you to 4th, OFTEN it sounds like the transmission is grinding away like a low rumble chatter. I've started shifting to 3rd instead. It blocks from 2nd but not to third.
2. Sometimes I swear I hear the throwout bearing making lots of whirring noise. I'm not sure if this is how I'm driving, clutching but it's a annoying. I can hear it over the radio.
3. I'm surprised at the amount of chatter the transmission can make if you don't feather the clutch just so. I'm not talking about the skip shift chatter. I know the difference. But I hear lots of metal clanking about. Now if I rev the car more and mind my clutching this isn't a problem. Perhaps this issues lie between the steering wheel and the floor as in my driving style. Perhaps I'm driving too much for mileage at the moment.
CrystalRedTintcoat is offline   Reply With Quote
Old 12-15-2012, 08:10 PM   #41
BLKSS1LE
Drives: 2013 Chevy Camaro SS 1LE
I agree, when I go through the parking lot if I am not appling gas it will chatter and metal against metal sound.I have speed bumps I have to go over and I crawl but still makes a lot of unpleasant sounds we will call them lol.
BLKSS1LE is offline   Reply With Quote
Old 12-15-2012, 08:15 PM   #42
BLKSS1LE
ALRIGHT GUYS! I called the deal about my car not going into reverse and they told me to bring it in.. but it only happened twice. Instead of going after the lemon law I am taking the more expensive and least amount of time approach, TRADING IT IN!! It almost brings tears to my eyes because I love everything else about the car, but I will not go through this tranny crap any longer! this is a 40,000 dollar car and GM should not allow this crap to happen and need to Fix the ISSUE with the TR-6060. Best of luck to all the guys out there that have similar issues and will have these issues. I want to thank everyone for your support and it has been a rough ride, but at least I can say I tried to own such a great piece of American muscle.
