JDP Motorsports
Old 06-06-2009, 10:33 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Shifter makes a glitch sound in the dash?
Has anyone had the issue of their Camaro making a snapping sound up in the dash around the column when they depress the release on the shifter?:(
If you press it multiple times it makes the snapping noise each time you depress it.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 06-06-2009, 10:34 PM   #2
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Im assuming Auto ?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 06-06-2009, 10:34 PM   #3
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
If it's an automatic, then yes. That is part of the safety mechanism to prevent you from shifting out of Park without the brake depressed.
Inspector 17 is offline   Reply With Quote
Old 06-06-2009, 10:42 PM   #4
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
My passengers necks make a snapping sound when I grab 3rd gear, nothing in the dash so far though. good luck
________
FREE DRUPAL THEMES
superstockcam is offline   Reply With Quote
Old 06-06-2009, 11:01 PM   #5
edog
edog's Avatar
Should it make the sound with the brake depressed?
I just went out to start and press the brake. The sound is still there. It is definitely coming from in the dash around the steering column. I listened to the sound from the engine area, but the sound is from in the car.
Old 06-06-2009, 11:03 PM   #6
edog
edog's Avatar
It sounds like a measuring tape bending past the flex point. It had not done it before last night. How do you get it quiet again? I will be taking it back in to the dealer to finish a different issue, so I will have them look at it.
Old 06-06-2009, 11:04 PM   #7
cam2fst4u
cam2fst4u's Avatar
Drives: 08 SS trailblazer,08 Silverado
Send a message via Yahoo to cam2fst4u
yes it should be fine .... But if you want me to test it out just let me know
cam2fst4u is offline   Reply With Quote
Old 06-06-2009, 11:06 PM   #8
Inspector 17
I love crepes
Since you are going back, you can have them check it out anyway, but I think that sounds about right.
Old 06-06-2009, 11:37 PM   #9
King Mouse
King Mouse's Avatar
Drives: EXT
It sounds like a relay (not bad but normal)
King Mouse is offline   Reply With Quote
Old 06-07-2009, 01:27 AM   #10
Vash
Drives: 00 Blazer
Yea converting some low amp in the switch to high amp probably going to the servo control.
Old 06-07-2009, 09:41 AM   #11
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
FirstLSK is offline   Reply With Quote
Old 06-07-2009, 01:11 PM   #12
Rally Sport
Drives: 2010 2SS RJT
haha, can't wait!!!!!
2LT RS CGM 6M on order
Rally Sport is offline   Reply With Quote
Old 06-07-2009, 01:17 PM   #13
Merica
Drives: Drives a 2010 SIM 2SS
lol:laughabove :
Merica is offline   Reply With Quote
Old 06-08-2009, 09:37 AM   #14
Inspector 17
I love crepes
Hey edog,
I just checked my truck (Nissan Frontier) and it makes the exact same sound. It has since day one and it has never been an issue.
Short Throw Shifter Constrained?? josh1147 Camaro Price | Ordering | Tracking | Dealers Discussions 75 02-19-2009 01:51 PM
Surround Sound Help! T! E! X! A! S! Off-topic Discussions 3 01-24-2009 06:55 PM
