Cold Air Inductions
Old 11-23-2012, 12:32 AM   #15
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
either way it'll look good!
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 11-23-2012, 12:33 AM   #16
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
MARINE1991 is offline   Reply With Quote
Old 11-23-2012, 12:38 AM   #17
ayousef
ayousef's Avatar
Drives: 2013 ZL1
the GT9 cam will kill a bunch of low-end torque and make it up in the high end, just so you know we spin a TVS2300 camaro 6900 because it makes peak power there with the GT9, this is with low boost from the blower. If you're making high boost youll peak at a lower rpm and make up for the low rpm torque loss. Plus it doesnt surge or buck.
I was also told to install the GT9 and advance it 4 degrees for a better overall power curve by a dude who specs cams for a living, might want to try that.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 11-23-2012, 01:16 AM   #18
MARINE1991
MARINE1991's Avatar
That's going to look awesome, is yours the waffle top, or the slp version?
its waffle... can make waffles too...
Old 11-23-2012, 02:23 AM   #19
Jessika
Drives: Anything Blown
sent from my Note2 using Tapatalk
Jessika is offline   Reply With Quote
Old 11-23-2012, 05:53 AM   #20
maxdmax
maxdmax's Avatar
Drives: 2010 Camaro SS/RS
I had a G5XB and it is a great blower CAM no overlap and not too aggressive. Makes great power.
LPE 417 - TVS2300 787 RWHP 759 Torque - Built by WWW.KYSPEED.COM
maxdmax is offline   Reply With Quote
Old 11-23-2012, 06:47 AM   #21
2010SSRSM6
2010SSRSM6's Avatar
I'm running a CMS custom grind on a Comp Cam. Before the blower I picked up about 60 HP, with the Maggie and OD cogs with the 3.8 pulley it picked up just a hair over 200rwhp @ 9.5 pounds of boost. I think it was in the $350 range for just the cam.
Old 11-23-2012, 11:22 AM   #22
MARINE1991
MARINE1991's Avatar
Old 11-23-2012, 11:34 AM   #23
catalan
Drives: -
I'm looking for the same thing which fits the TVS 2300 but i need a good decent powerful cam which is stealth in idle just like the stock (i just don't want the noise).. I also have L99 but not planning for the LS3 conversion ..
Which one do you recommend guys ?
catalan is offline   Reply With Quote
Old 11-23-2012, 12:25 PM   #24
2SS45th
2SS45th's Avatar
You'd have to get a VVT cam then. TSP has ome of those, but if it were me, I would be doing the conversion. Your options would be far greater if you do that. I would also recommend the GT9, LS9, or Jannety Smooth Idle cam in that case.
These are your options for keeping the AFM lifters in place: http://texas-speed.com/c-234-camshaf...c-engines.aspx
Old 11-23-2012, 05:58 PM   #25
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I would find some one who can spec a cam to YOUR specs,your needs and wants .No reason for a cam sitting on the shelf,why comprimise? I would find someone who not only has several 2300 builds over 800rwhp but has a vast knowledge of the PD blowers and knows how to get you where you want to be.I would look for proven results and tons of happy customers from mild to wild.Our number is 980-521-0722 we can get you the right cam the first time
Hendrix-Engineering is offline   Reply With Quote
Old 11-23-2012, 06:18 PM   #26
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
We have a cam in stock with all supporting components that will pickup 80-100rwhp on a TVS 2300. Our camshafts have proven to make the most HP/TQ and still maintain exceller drive-ability.
Edit, just read you did not want to ditch the L99 stuff. The gains will not be as significant but I would really suggest removing all of those components to prevent failures anyway
Meister@Torq is offline   Reply With Quote
Old 11-24-2012, 01:32 AM   #27
MS7
MS7's Avatar
Drives: 2011 camaro LS3 supercharger
I recommend the GT9
1- great sound
2- 95% same stock
3- great power
i made 580 RWHP only cam and LT headers & intake.with maggie
you will love this cam
MS7 is offline   Reply With Quote
Old 11-24-2012, 01:33 AM   #28
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
The LPE GT-11 cam is another great option. OEM driveability and stealth sound. Whatever cam you choose you will need to ditch the AFM lifters otherwise I wouldnt add a cam at all.
