Frankenstein Engine Dynamics
Old 11-23-2012, 04:10 PM   #1
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Rear Differential Chatter/Howl-Problem Solved
Anyone who can change their oil can and should do this. Took my ZL1 to the dealer to check the rear diff noise and they said they planned to change the seals and diff fluid. 3 hr job to tear out the half shafts and replace seals and use the new fluid. But what they didn't know is the ZL1 already has the new fluid and compatible seals. And I wasn't thrilled at the idea of them tearing it down. So I went out and got some good quality Valvoline Synthetic 75W-90 and did it my self. No more noise, much smoother. Didn't see the sense in dealer putting the same stuff in that was making noise already after 4000 miles. Anyone who tracks should change the fluid regularly. I did one track day since I bought my car in May and just got around to changing the fluid.
Pulled it on ramps on the incline of the driveway so the fluid in the cooler would run to the back when drained.
Both the plugs are magnetic and will have a little debris on them.
Note the top fill plug has a paint mark I assume to keep you from over tightening.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 11-23-2012, 04:13 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
BTW it holds about 2 1/2 quarts. And I took it out for a drive first to warm up the fluid first and it drains very quickly that way.
Old 11-23-2012, 04:19 PM   #3
Skylane765
Skylane765's Avatar
Drives: Camaro's Challenger
I thought the rear end now use auto transmission fluid, so only the manual trans uses automatic trans fluid?
Skylane765 is offline   Reply With Quote
Old 11-23-2012, 04:20 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
if it starts making noise when it is cold on slow turns, go to the dealer and get the additive or LS gear oil that has the additive in it already. I tried Royal Purple but it started howling and chattering after a few days when it was cold. Switched back to GM LS gear oil and it was all quiet again.
'17 ZL1 A10 Mosaic Black PDR/Nav
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 11-23-2012, 04:21 PM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
incorrect info here
Old 11-23-2012, 04:27 PM   #6
ZO6 Bryan
ZO6 Bryan's Avatar
No, manual calls for 75W-90 gear oil. The oil I used doesn't require any additional additive. And actually the manual calls for additive in the SS but not the ZL1. The GM LS gear oil 88862624 that is recommended for the ZL1 in the manual doesn't require additive.
Old 11-23-2012, 04:29 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Copied from owners manual
Rear Axle (V6 Engine with Manual
Transmission)
Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 89021677 and
Friction Modifier 1052358, in Canada 89021678 and
Friction Modifier 992694).
Rear Axle (SS)
Rear Axle (ZL1)
Rear Differential Fluid 75W-90 Limited Slip (GM Part No. 88862624, in
Canada 88862625).
The TSB for the rear diff noise has the dealer replace the oil in the diffs of the SS cars with 88862624. Already in the ZL1!
Old 11-23-2012, 05:23 PM   #8
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
Heres the TSB you mentioned for non-ZL1's
Service Information
2012 Chevrolet Camaro | Camaro VIN F Service Manual | Document ID: 2740658
#PI0137C: Rear Axle Chatter Type Noise on Low Speed Turns (Excluding ZL1) - (May 11, 2012)
Subject:Rear Axle Chatter Type Noise on Low Speed Turns (Excluding ZL1)
Models:2010-2012 Chevrolet Camaro (Excluding ZL1)
Equipped with Limited-Slip Differential (RPO G80)
Attention:For 2010 and 2011 vehicles built prior to August 25, 2010, if the chatter noise you are experiencing occurs only in Reverse while making a turn, please review the latest version of PIC5424.
This PI is being revised to add an Attention statement and update the Recommendation/Instructions. Please discard PI0137B.The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on a chatter-type noise from the rear of the vehicle while making low speed turns.
This condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise.
Caution: The rear axle seals must be replaced. The original seals are not compatible with the new fluid.
Replace both rear axle shaft seals with GM P/N 22798805 and drain/refill the rear differential with new fluid, GM P/N 88862624 (in Canada, use P/N 88862625). Refer to the Rear Axle Shaft Seal and Differential Oil Replacement procedures in SI. This fluid includes a limited-slip additive (friction modifier) already added. DO NOT add any limited-slip additive (friction modifier).
Important: Please advise the customer that once the differential fluid has been changed, it may take as long as 805 km (500 miles) for the lubricant to fully penetrate the limited slip clutch plates. During this period some chatter may still be felt on initial startup while making slow turns until the rear differential fluid warms up.
Note: DO NOT re-use the wheel drive shaft nut. Replace with NEW only.
Parts Information
Part Number
Description
Qty
22798805
Seal, Rear Axle Shaft
2
11611687
Nut, Rear Wheel Drive Shaft
2
88862624 (US -1 qt)
88862625 (Canada -1 L)
Fluid, Manual Transmission (Dexron LS Gear Oil 75W-90 MTF)
1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
F9739*
Replace Both Rear Axle Shaft Seals and Drain/Refill Rear Axle Fluid
3.1 hrs
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 11-23-2012, 05:29 PM   #9
MS3DALE
MS3DALE's Avatar
Thats a "quality control" mark if you will,it means the diff. has been filled and the plug tightened at the assembly plant.
Old 11-23-2012, 08:09 PM   #10
SlugWound
SlugWound's Avatar
Drives: Chevrolet's
Great info, thanks for posting
2013 ZL1 M6 # 2286 /ROTOFAB CAI
SlugWound is offline   Reply With Quote
Old 11-23-2012, 09:48 PM   #11
DangerZL1
Drives: Accord
The transmission fluid mentioned is only for the diff cooler. I had a Valvoline lube place change mine while I watched using the GM recommended fluid. They said their fluid met the GM spec, but I elected to use the GM fluid instead. It's only about $40 to have them do it versus $100+ for the dealer.
DangerZL1 is offline   Reply With Quote
Old 11-23-2012, 10:14 PM   #12
ZO6 Bryan
ZO6 Bryan's Avatar
That's right, the ATF is circulated the length of the car not the diff fluid. I had looked at it before but forgot how it was plumbed. So really was no need to lift car and keep it level to drain. Just the rear up in the air would have been fine.
Old 11-24-2012, 06:46 PM   #13
OldScoolCamaro
...was it leaking...why did they have to replace the seals as you stated?
Old 11-24-2012, 11:23 PM   #14
ZO6 Bryan
ZO6 Bryan's Avatar
No leaks. The TSB for the SS cars tells them to replace the seals with new part # to be compatible with the new fluid. The ZL1 already has the new seals.
