SDTW Custom Wheels & Tires
Old 11-25-2012, 01:08 AM   #15
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
Love to read threads like this one. I'm always learning and when the time comes I can always refer back to it. Thanks for posting.
Normagene is offline   Reply With Quote
Old 11-26-2012, 08:52 PM   #16
Catfish
Catfish
Catfish's Avatar
Drives: 2012 Camaro ZL1 #361
Be careful with the synthetic fluids. Not all of them hav ehte additive included. I know that Mobile 1 doesn't.
2012 ZL1 VIN# : 361
DELIVERED ON 4-12-12
Victory Red, Alum Wheels, Manual, Carbon Fiber Mohawk
Performance Mods to Date:
Rotofab cold air intake, Kooks 1 7/8" LT headers w/ Calico KoolBlack ceramic coating, Kooks high flow cats, Corsa 3" X-pipe cat-back exhaust, 160 degree thermostat, 2.50" Supercharger Pulley, PCM Catch Can, Rotofab Supercharger Reservoir, 1000cc Injectors, MSD Boost-a-Pump,Tuned by PCM of NC
604 RWHP & 622 RWT !!
Also, 2001 Silverado Z71, Pewter w/ Extended Cab & 2013 Chevy Cruise LTZ/RS White
Catfish is offline   Reply With Quote
Old 11-26-2012, 11:31 PM   #17
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The Mobil 1 LS 75W-90 gear oil does have the additive already. I looked at that one too.
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 11-27-2012, 05:25 AM   #18
DangerZL1
Drives: Future ZL1 Owner
Mobil 1 Synthetic Gear Lube LS 75W-90 does not have enough LS additive to meet GM spec #88862624. This is why I went back wit the GM fluid. I didn't want to use more additive, nor add more than necessary. I think Valvolines synthetic gear lube meets this spec.
DangerZL1 is offline   Reply With Quote
Old 11-27-2012, 07:49 AM   #19
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 2014 SS sedan
To the o.p. The owner's manual specifically says to change your diff fluid after every track day. If you tracked it a while ago...and just now got around to changing your fluid...that's what could have caused the chatter.
I had the chatter in my SS, but I got my techs at work to upgrade me to the LS gear oil with new seals and all is well!
2018 MBM ZL1 6spd Coupe.
Current toy-02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles.
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 12-06-2012, 10:12 PM   #20
Les7311
Les7311's Avatar
Drives: 45th Anniv, 2SS, LS3, '07 M109
Send a message via Yahoo to Les7311
subscribe
Les7311 is offline   Reply With Quote
Old 04-29-2013, 12:43 PM   #21
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
So how is everyone's diff doing now?
Does the valvoline fluid work fine over the lung run wihout needing to use the LS additive?
2017 C7 GS - WGG, A8. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 04-29-2013, 01:11 PM   #22
hognutz
hognutz's Avatar
Drives: 2013 ZL1
The original poster added some extra addative to the valvoline oil eventually.
here is my .02 on this topic take it for what it is worth. buy some good fluid. IE the gm fluid, good aftermaket synthetic. Now if the fluid has addative don't run any extra up front. If you buy fluid without the additive use the recomnended GM addtive right out the gate.
after you fill the diff do some figure eight driving in a parking lot to cycle the diff clutches. I think the GM TSB specifies how many to do
Now if you still get some chatter go get more of the GM addative that is recomended at add say 2 ounces at a time then go repeat the figure 8's until the chatter is elimitnated.
the friction modifer material is not a more is better type thing you need the right amount.
my fresh gm fluid will be here this week I will do the change and if I get a bit of chatter I will do just what I posted. I am positive it will work because it worked on my Z06.
my chatter is very minimal on my car right now and only when cold but I want it 100% gone. sometimes I think with these tires having such piss poor grip in the cold it magnifies the issue.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 07-12-2013, 10:25 AM   #23
ZL1Reaper
ZL1Reaper's Avatar
Drives: '13 Silver Ice Metallic ZL1
I tried the Mobile 1 in my car. Definitely not enough additive in it. When the car is cold, the differential makes more noise than when it had the GM fluid. I'm gonna try Valvoline next.
ZL1Reaper is offline   Reply With Quote
Old 07-12-2013, 10:37 AM   #24
DangerZL1
Unfortunately, Mobil One doesn't meet the spec. The GM/DELCO fluid was expensive but worked well.
Old 07-12-2013, 11:14 AM   #25
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
There is now a bulletin out on this, it calls for the dealer to flush and fill three times along with some figure 8s, etc. I had mine done and it silenced the howling.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 07-12-2013, 11:29 AM   #26
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat
I think my ZL1 has this problem. I just didn't know what the hell it was.
FINALLYSATISFIED is offline   Reply With Quote
Old 07-12-2013, 11:38 AM   #27
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Don't know when the bulletin came out or whether my dealer did all that, but they pulled it apart to check it last year and refilled it and mine has been fine since. Basically what this guy said.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 07-12-2013, 11:52 AM   #28
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
I just came back from my dealer and cant believe they were going to put the wrong fluid in the car. The tech looked at me like "who the hell is this guy" I told him that this car uses a fluid from gm with the additive already in the car. He went to parts and came back with the right stuff.
When filling he used 2 bottles/quarts of the fluid and pumped it in then I reminded him that in needs 2.1 and he again went and got another bottle and pumped in about 1/2. Some fluid came out and we watched it drain from the fill plug and closed it up when it started to drip.
Makes me thank this forum and its memebers for the insight and info. I pray this guy torqed the bolts right.
Now that I think about it i hope he cant overfill the thing........
Laus Deo
charlietuna is offline   Reply With Quote
