JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 11-24-2012, 08:24 AM   #1
ZL1Bullet
ZL1Bullet's Avatar
Drives: ZL1
Best way to suspend ZL1 (removing wheels)???
Quick question - Are jack stands ok for suspending a ZL1 over winter so I can remove the wheels for warm storage. My garage is detached and not heated. I'm trying to follow the manufacturers guide lines.
Is there something better to use?
2013 Ashen Grey ZL1, exposed Carbon Fibre insert, Sun Roof, Bright Wheels, NAV Radio
ZL1Bullet is offline   Reply With Quote
Old 11-24-2012, 02:10 PM   #2
SQUALO
SQUALO's Avatar
Drives: LT/RS Hyper Blue white rally stripe
IMOP
Removal of tires is not necessary for winter storage, that's more for long term storage.
I lay a tarp down on the garage floor,wrap it up over the tires and then use my high quality car cover (Hugger car cover). I've been doing this for 3 seasons and never had any issues in the spring.
Again, that's my opinion/storage method, you have to decide what's best for you.
(Drive Safely & Responsibly)
Old 11-24-2012, 05:14 PM   #3
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Mine sits on rubber mats with a car cover
tpower is offline   Reply With Quote
Old 11-24-2012, 05:40 PM   #4
gramps_green_rs
ex-RCAF
gramps_green_rs's Avatar
Drives: 11 SGM1LTRS SV1000S
have to agree with the above. probably not cold enough in London to worry about taking the wheels off.
gramps
gramps_green_rs is offline   Reply With Quote
Old 11-24-2012, 06:51 PM   #5
gs-63
Drives: Camaro
My garage is not heated either. I store my ZL1 on "FlatStopper" from Race Ramp and
leave the wheels on.
gs-63 is offline   Reply With Quote
Old 11-24-2012, 07:42 PM   #6
CDN SS
Steve from Canada.
CDN SS's Avatar
Drives: 2010 SW SS/RS with Inferno package.
X2
CDN SS is offline   Reply With Quote
Old 11-24-2012, 11:06 PM   #7
Zdrrguy
Resident "Fbody" Member
Zdrrguy's Avatar
Drives: 2010 2LT RS & 91 Camaro V8 RS
Send a message via Skype™ to Zdrrguy
Leave the wheels on it, but go to Home Depot or Lowes whatever and get some 1" hard styrofoam ( about a half sheet will do) and cut into quarters and place out where the car will be parked so the car sits on top of them!
The styrofoam will obsorb the weight of the car and avoid flatspotting!
CCFBG-1 1991 Camaro RS Phantom Grey/CCFBG 2-2010 2LT RS Black on Black
Mark....President/Founder of www.CCFBG.com
Zdrrguy is offline   Reply With Quote
Old 11-24-2012, 11:19 PM   #8
C586
Drives: 2011 Camaro LS
Letting the suspension hang is a horrible idea. The suspension is not designed the hang for a long period of time. Just park it with some defense against mice and a tender if possible and leave it. Don't start it periodically. Leave it alone til spring
C586 is offline   Reply With Quote
Old 11-24-2012, 11:32 PM   #9
Zdrrguy
Zdrrguy's Avatar
Yuup, Use dryer bounce for the motor area and interior, they hate the stuff.
Old 11-24-2012, 11:50 PM   #10
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
I'm not saying mice don't hate that, but I'll just forward what I heard at the dealership when I had my Impala serviced over a year ago. They found a mice ate some electrical wiring under my engine cover. I asked them about dryer sheets, they said some mice hate them, but some mice don't mind. They also said they've heard of mice actually using dryer sheets as nesting material. Go figure!
Not sure if it's 100% accurate or not, but thought I'd share.
One thing that should work is poison and snap traps. That's the only thing I would really worry about for storing it for long periods.
That, or put a car cover on and get a garage cat to watch your car.
SPARTAN sui is offline   Reply With Quote
Old 11-25-2012, 01:09 AM   #11
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
You're probably going to be in the 'maybe' zone for storing the tires warmly. Chances are you'll be OK with them in the garage & on the car ... but I wouldn't say you're being obsessive by removing them & storing inside either.
In any case, I'm moving this discussion to the general ZL1 forum because this topic probably affects more Americans than it does Canadians.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 11-25-2012, 08:15 AM   #12
DangerZL1
Drives: Accord
I don't think it would be a problem to store it using the above suggestions. Mine was one of the early builds that sat out in the weather in Canada with snow all around it during the quality hold and I didn't notice any problems with the tires. As long as the tires warm up before you move it, you should be fine. I'd also inflate them to 35 psi.
DangerZL1 is offline   Reply With Quote
Old 11-25-2012, 08:31 AM   #13
gew248
Drives: 1968 Camaro; 2012 ZL1
For mice, I purchased a Pest Pro from Lowes. I put it on the garage floor in front of of the car. Here is the one I bought.
http://m.lowes.com/pd_238786-1558-M7...ductId=1067673
gew248 is offline   Reply With Quote
Old 11-25-2012, 09:05 AM   #14
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
My winter routine is a good cleaning, cover, and inflate tires up to 40 psi. I think running the car up on some hard rubber or styrofoam would be a good idea, but I've never done that. Battery tender is a must as well.
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
