B&M Racing
Old 11-25-2012, 09:25 AM   #1
gdl029
CAROMARO
gdl029's Avatar
Drives: 2012 Ashen Gray 1LT
Rear speaker removal
Does anyone know of a thread that shows how to remove the rear speakers.
gdl029 is offline   Reply With Quote
Old 11-25-2012, 12:35 PM   #2
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
http://www.camaro5.com/forums/showth...peaker+install
RobertHarriSS is offline   Reply With Quote
Old 11-26-2012, 12:05 PM   #3
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
Not sure if youve done this yet or not but just unbolt the back seat bracket. Sure as hell alot easier and only takes 1 person not 2. 4 bolts and 1 nut and youre done. Plus allows you to dynamat in the braket area alot better if you desire
PIPE
PIPE is offline   Reply With Quote
Old 11-26-2012, 12:17 PM   #4
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
i have speakers too that i bought and are just collecting dust, but those instructions look pretty crucial. GEEZ!
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 11-26-2012, 02:38 PM   #5
thino
thino's Avatar
its a pain, and do not skip a single step because taking it a part is easy, putting it all back without damaging anything is the hard part
thino is offline   Reply With Quote
Old 11-26-2012, 08:11 PM   #6
zkdreads
zkdreads's Avatar
thats what im afraid of
C-LO or Sonic
Old 12-02-2012, 12:59 AM   #7
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
any more info on doing it this way? sounds alot better if it works
godeepdown is offline   Reply With Quote
Old 12-02-2012, 10:33 AM   #8
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Like PIPE said, it's very easy. I just used my electric impact wrench and had the seat out in about 2 minutes.
jeepguy_1980 is offline   Reply With Quote
Old 12-06-2012, 09:33 AM   #9
PIPE
PIPE's Avatar
Just seen this my bad. I believe center nut is 17 or 18 mm . The 4 outer bolts i believe are 14 or 15 mm. Just remove them all and lift out. hold top of seat by the unlatch loop and grab the bottom of the seat at the same time. slowly take out of back without hitting any of the trim pieces.
PIPE
Old 12-12-2012, 03:59 PM   #10
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
The hardest part is removing and installing the rear deck. Removing the rear seat and side panels are cake.
there's a few tips in my thread here may be helpful.
http://www.camaro5.com/forums/showthread.php?t=213736
IDEALG is offline   Reply With Quote
Old 12-12-2012, 07:12 PM   #11
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I did not even try to install my rear speaker. I had audio install it for me. $60.00 to install and have deader put down. I supplied the speakers spacer and the Dynamat. Went next door and had a couple slices of pizza. it took them about and 11/2 hours but was worth it.
Caddy
Caddyroger is offline   Reply With Quote
