Old 11-25-2012, 04:20 PM   #1
k5and
Drives: 2013 Silver Ice Metalic ZL-1, #3026
bi-mode exhaust weirdness?
So, mebbe should not ask/complain, but....
my new zl-1 seems to always have exhaust dampers open. i thought they were supposed to be closed until rpms up to 3500 or so? i checked the F8 10 amp fuse, but it is good. would appreciate theories, suggestions. thanks.
k5and is offline   Reply With Quote
Old 11-25-2012, 04:27 PM   #2
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Did you confirm they are open at idle and get out and actually eyeball up the outer pipes?
By the way, see this is your 2nd post. WELCOME to Camaro5!
Maker sure to go to the ZL1 section and post your VIN on BeckyD post.
One-Bad-ZL1 is offline   Reply With Quote
Old 11-25-2012, 04:30 PM   #3
k5and
Thanks. Yep, checked at idle and they're wide open. #3026, and yes, did add to list.
Old 11-25-2012, 04:33 PM   #4
scottzl1
scottzl1's Avatar
Drives: 2017 ZL1
FYI...
The valve (loud) is open until 1000rpm...then closes...then opens back up @3000rpm. That is my observation...I am installing the mild to wild next week to keep it open at a times!!!!
Scott
scottzl1 is offline   Reply With Quote
Old 11-25-2012, 04:34 PM   #5
One-Bad-ZL1
Did u climb under the pipes to make sure the butterflies are freely moving by hand?
Are both butterflies behaving the same or is one open and one closed?
Old 11-25-2012, 04:34 PM   #6
Dr.Spike
Dr.Spike's Avatar
Drives: 2013 Camaro ZL1 (IOM)
Before I pulled the fuse, mine were open at idle. They would close around 1000 and open up again around 3000.
Dr.Spike is offline   Reply With Quote
Old 11-25-2012, 04:41 PM   #7
One-Bad-ZL1
Sounds like with two people, you could see if they are behaving as they should. Let us know and if they are not, we'll keep going down the diagnostic path. But let's confirm a problem first.
Old 11-25-2012, 04:55 PM   #8
k5and
All....the butterflies behave the same. They move freely by hand (not stuck). As rpms increase from idle thru 2000, they don't close. Thanks to Scott and others who described how theirs function from idle thru 3K. I'll keep searching, but not really a problem, just not how I understood it to function.
Old 11-25-2012, 05:26 PM   #9
Dr.Spike
Dr.Spike's Avatar
Did you check to see if the vacuum lines got disconnected?
Old 11-25-2012, 05:37 PM   #10
k5and
Spike...no joy....they're connected.
Old 11-25-2012, 05:37 PM   #11
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
Correct function is that they are open at idle to 1,000rpm, then closed to about 3,000rpm when they open up again.
They won't close at all however if you are above 25% throttle.
If they are not closing at all though regardless of throttle amount then it could simply be a blown fuse, so try changing that first and see if there is any change
Modern07 is offline   Reply With Quote
Old 11-25-2012, 05:42 PM   #12
k5and
Modern07..thanks for dope. Fuse is good.
Going to stop fretting and just enjoy the sounds.
Old 11-25-2012, 06:43 PM   #13
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
That sounds like the fun plan. I love my dual exhaust.
Scott@Bjorn3D is offline   Reply With Quote
Old 11-25-2012, 06:52 PM   #14
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
