Old 03-26-2013, 11:24 PM   #127
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
Originally Posted by Stealth 2010 2SS/RS View Post
You may want to get in touch with redline i think it is. I think they built a fast 1/4 mile ZL1, ask them how the rear is holding up, LPE would be a good one too. I weighed the diff the other day and came in at 144 LBS so its a beefy unit.
Great suggestion! The redline ZL1 is at 750 whp with no modifications to the drive line and no issues to date. He says he has a number of ZL1s in the 800s with no issues to date as well.
I think i'll probalby go the ZL1 route...may wait for a little better price though.
PMJ is offline   Reply With Quote
Old 03-26-2013, 11:55 PM   #128
PMJ
Seeking 9s on M6...
PMJ's Avatar
I spoke too soon...just pulling the price on the Diff, axels & drive shaft on GMPartsDirect was a little over $3K, but added around $800 S&H. I guess i'll be calling my local Chevy dealer back...looks like they gave me a good price.
Old 03-27-2013, 12:26 AM   #129
Bomino
Bomino's Avatar
Drives: 2011 2ss/rs
Why not the hammerhead? I mean obviously it is to save money, but being that the hammerhead shell is aluminum, your gonna be saving weight. not only that, but DSS stands behind their product, and if something goes wrong, your dealing with someone who is going to be a lot more willing to help than GM.
the axles would also be much stronger, and you can upgrade the driveshaft to a 1-piece while your at it for an overall smoother drivetrain.
To me it seems like a worthy investment for a couple grand more.
If your gonna spend 4k, why not 6k, right? haha
Bomino is offline   Reply With Quote
Old 03-27-2013, 01:59 AM   #130
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
Are they autos or sticks?
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
MGW Short Throw Shifter
Complete ZL1 Rearend Swap
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 03-27-2013, 03:39 AM   #131
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Originally Posted by Bomino View Post
your gonna be saving weight, unsprung weight.
It's sprung weight. The center section is mounted to the chassis.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 04-01-2013, 04:23 PM   #132
Stealth 2010 2SS/RS
Anyone have a part number for the ZL1 trans flange thats not in the gm performance book or any other place besides ADM that makes a trans flage adapter?
2010 LS3 2SS/RS M6
Old 04-01-2013, 06:24 PM   #133
10 2SS/RS 6M
10 2SS/RS 6M's Avatar
Drives: 2010 Camaro 2SS/RS 6M Black-s/s
Why not just go with the flange from ADM? Probably cheaper.
I'll call my parts guy at my Chevy parts dealer to see if he can get it, I have to call him anyway to see what's up with the whole ZL1 IRS kit, an it's availability. I'm thinking of buying the axles, 1K HP DSS axles to the stock diff, I hear they bolt right up to the HammerHead since the dimensions are the same, then as the $ grows I'll add the HammerHead and the driveshaft.
SLP- long tube headers, hi flow cats w/full SLP 3'' PowerFlo exhaust incl/X-pipe, 160 degree stat, SLP Blackwing CAI. Dyno tuned by ECS-407/409RWHP&TQ. BMR- trailing arms w/poly knuckle bushings, toe links, cradle bushings and differential bushings. QA1 rear lower control arms. Hurst short throw shifter, DSS- level 4 axles, DSS- aluminum driveshaft, Pfadt- sport 1.5" rear sway-bar. SPOHN 1.25" front sway-bar. Monster LT1-S twin clutch. Prothane motor mounts. Best 1/4 mile so far- 12:70ET @ 112.24 MPH w/ 2.06 60', 2010.
10 2SS/RS 6M is offline   Reply With Quote
Old 04-01-2013, 07:12 PM   #134
Stealth 2010 2SS/RS
The ADM adapter flange is $200 with the cost of the driveshaft i could be at gforce or dss one. Just trying to keep all ZL1 parts I have info saying they support some high numbers.
2010 LS3 2SS/RS M6
Old 04-01-2013, 09:25 PM   #135
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
There is an entire ZL1 rear end assembly listed on ebay for 4 grand.
OEM Manual LSA Rear Suspension Assembly 3.73 Gear Ratio Cooler
Used with 2000 miles, but might save someone time gathering components.
Southern Comfort is offline   Reply With Quote
Old 04-01-2013, 09:32 PM   #136
Stealth 2010 2SS/RS
It may save time but I'll have all new stuff for just at about $3500 minus the cooler.
2010 LS3 2SS/RS M6
Old 04-01-2013, 09:34 PM   #137
Jason P
Jason P's Avatar
Drives: 2011 2ss
Take yours out and go to a machine shop, and have the holes milled out.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 04-01-2013, 09:38 PM   #138
Southern Comfort
Not suggesting you change your plans, just an fyi for the audience.
Old 04-01-2013, 09:42 PM   #139
Stealth 2010 2SS/RS
Jason I'm in no real hurry, car isn't even out of storage yet. I'm just trying to find it the ZL1 trans flange will work with the ss trans and if there is a part number for it. Have you got a chance to play with the rear yet?
2010 LS3 2SS/RS M6
Old 04-01-2013, 09:46 PM   #140
Jason P
Jason P's Avatar
Drives: 2011 2ss
No. My zl1 fuel pump and msd voltage booster was the wrong combination according to Ted. So now I'm waiting on an LPE fuel pump to put in. I don't want to burn my car down but the waiting is killing me.
