Old 12-09-2012, 06:26 PM   #29
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I'm asking because the ZL1 seems like a more affordable and street friendly alternative to a 9" and people are making seem like it a whole project to install.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 12-09-2012, 07:26 PM   #30
Synner
Drives: not stock
I can't say its fun doing this kind of thing on jack stands but its not difficult. Just somewhat back breaking and time consuming. Depends on what you define as a "whole project" and your skill level.
Old 12-09-2012, 08:02 PM   #31
MA2010SS
Drives: 2010 Camaro SS
These gen5 camaros have to be some of the easiest cars I have worked on. Doing a rear swap as long as you have the right tools should about 2 - 3 hours to R&R everything using jack stands while taking your time doing that project. I can't wait to see the pricing on the ZL1 differential swap kit.
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 12-09-2012, 08:22 PM   #32
Chris82xx
Chris82xx's Avatar
"whole project", meaning I've been reading rumors that the Zl1 rear diff won't fir into the cradle of the SS. Is that a true statement or is just a simple swap out?
811RWHP/719RWTQ
Old 12-09-2012, 08:26 PM   #33
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
You actually believe something you found on the internet There is a lot of stuff that floats around and it simply isn't true. GM is seling the ZL1 upgrade as a BOLT in Kit.
Old 12-09-2012, 08:41 PM   #34
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
Originally Posted by blazzin1 View Post
Any guesses on the price? I'll throw out a "guesstimate" of around $2700. I just don't like the 2-piece driveshaft, I rather sport a 1-piece aluminum or carbon shaft.
I'd guess more. The ZL1 diff by itself has a retail list price of about $2500, D/S about $700, axles about $600 ea, nuts/bolts about $100.... That ZL1 stuff is pricey, compared to SS driveline parts. $4K ish would be my retail guess, hopefully though a lot less, and discounted by some dealers. Then you have tuning for the speedo error...
Old 12-09-2012, 08:43 PM   #35
Chris82xx
Chris82xx's Avatar
Hey, remember the commercial. You can't put anything on the internet that isn't true.
811RWHP/719RWTQ
Old 12-09-2012, 08:45 PM   #36
Chris82xx
Chris82xx's Avatar
One of the vendors on here sells the ZL1 diff for $1850. I used his prices and came roughly to about $3k. I'm just not pulling the trigger yet because I want to be certain that I don't need to do any modification to swap it out. Seems like I don't.
811RWHP/719RWTQ
Old 12-09-2012, 08:54 PM   #37
Synner
Drives: not stock
The ZL1 cradle has the tabs for the cooling lines for the diff cooler. As far as I know thats the only difference. And it aint hard to make something work for that if people even plan on adding the cooler which it seems like most aren't.
And who pays retail?
Old 12-09-2012, 08:59 PM   #38
Chris82xx
Chris82xx's Avatar
You can't pay retail. Takes the fun out of bargaining.
811RWHP/719RWTQ
Old 12-09-2012, 09:06 PM   #39
ADM PERFORMANCE
Drives: 2016 CAMARO SS
There is alot more differences than that,Replace it with the zl1 and never look back
ADM PERFORMANCE is offline   Reply With Quote
Old 12-09-2012, 09:12 PM   #40
Synner
Drives: not stock
Like?
Old 12-09-2012, 09:14 PM   #41
Chris82xx
Chris82xx's Avatar
811RWHP/719RWTQ
Old 12-09-2012, 09:15 PM   #42
JusticePete
VIR Specialist
Like?
The sub-frame bushes that are part of the GM kit.
