Old 06-07-2009, 04:02 PM   #1
Adam
You Said Member
Drives: 2010 SIM 2LT Auto RS
fine scratches on new camaro after drying
My question is, do you think it's possible I did it? I used three zaino towels to dry the outside of the car.
I tried to do it as lightly as possible and still get it dry.
I never noticed the scratches before, but they are really really fine, so I could have easily missed them.
If you guys think I probably did this, then I'm just going to have to deal with water spots I guess, because I don't want to mark up my car, even if it's fixable, I'd rather just not have it happen at all.
Thanks for any info.
Adam is offline   Reply With Quote
Old 06-07-2009, 04:08 PM   #2
jakemaxx
jakemaxx's Avatar
Drives: 1969 impala
http://www.autobarn.net/ac20002.html
only thing i will ever use on a car again.
ordering 1SS, IOM, White Stripes, Sunroof, BA Sound System, RS Package, LS3 6M
:5thgenvert:
jakemaxx is offline   Reply With Quote
Old 06-07-2009, 04:26 PM   #3
Adam
You Said Member
I don't really see how that could dry irregular surfaces. I was thinking of getting one of those filtered blowers though.
Old 06-07-2009, 04:37 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It is possible you did it while washing. Was there any really bad dirty spots on it?
I doubt you did it while drying though unless you dropped one of the towels. Do you remember which areas each towel dried? Are the scratches all on that same one area or do they go into other areas where another towel dried? Did you dry the car using vertical or horizontal motions? Are the scratches following the same pattern?
Old 06-07-2009, 05:22 PM   #5
jakemaxx
jakemaxx's Avatar
Drives: 1969 impala
that was a bad example they have made a new one with a flexable handle that will adjust to any curved serfaces
:5thgenvert:
Old 06-07-2009, 05:31 PM   #6
Adam
You Said Member
there's an almost matching set of scratches above each door window, going vertical, which was the motion I made. Never dropped the towels, but I did get some dirt on them from the car while drying.
I should examine the entire car and make mental notes of any other surface imperfections. There was something almost like clearcoat scuffing underneath the trunk bowtie, that I know I couldn't have done, and never saw until today as well.
Old 06-07-2009, 05:46 PM   #7
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
First, your drying towel should not ever get dirty. If it does your car was not washed. The best way to dry IMO is to just lay the towel on a spot and let it soak it up then lift it up and wring it out, move to next spot. No real worries though you can use one of zaino'a swirl and scratch removers and recover from this whole ordeal. Did you let the dealer do a wash on the car? They might have damaged it upon the PDI. I hope this situation works out for you cause I totally understand the feelings you must be having finding the first flaws on your car. I have been washing mine daily cause of bugs and have gotten to know mine pretty well. I opted for NXT and use ultimate detailer for maintanence. Very happy with the depth it added to the IBM color. Also made the slight orange peel dissappear and looks like an entirely different paint job.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 06-07-2009, 06:57 PM   #8
Adam
You Said Member
Dealer hadn't even unwrapped it.
I tried laying the towel and picking up, but it left droplets behind anyways.
Honestly I don't feel that bad about it, I just want to see if I should avoid towel drying.
I pressure washed the car, because that's the easy thing to do for my current situation, plus I was trying avoid contact with the car as much as possible. But apparently that doesn't clean it all that well.
Old 06-07-2009, 07:14 PM   #9
GLBL WMR
Booya
GLBL WMR's Avatar
Drives: Black 2010 2SS/RS
You probably did do it, and they're probably only spiderweb scratches that that will buff out with a mild polishing. To prevent it from happening again, use this:
http://www.adamspolishes.com/p-106-a...ing-towel.aspx
This towel is so soft and absorbent its ridiculous.
2010 Camaro SS/RS RP6 | 2SS package, M6, black, black leather
2000 Blazer LS | winter beater
GLBL WMR is offline   Reply With Quote
Old 06-07-2009, 07:21 PM   #10
GM Kid
Drives: 2005 Pontiac GTO
Yeah, pressure washing isn't the best. Nothing replaces physical contact with the car--preferably with completely clean wash water and a microfiber wash mitt. Rinse the car thoroughly first, then gently wash. Often, I'll wring the mitt and drench the surface with suds before I let the mitt touch it, just to ensure PLENTY of water is on the paint. Use straight strokes, not circles. Clean dirty areas like wheel openings and the bottom of the car last.
After rinsing, I use a leaf blower on areas where water likes to hide. Then I use a large blue microfiber drying towel. Remember that a bone-dry towel can be tough on paint, and it won't absorb water well. That's why I try to do the windows first--you can't really hurt 'em, and the moisture kinda "primes" the towel for the rest of the car. Again, remember to dry potentially hazardous areas like wheel openings and the bottom of the car LAST.
As for the fine scratches you found, a foam pad and most any good cleaner/wax would be a mild solution. Be sure to rub off the wax with a microfiber towel. If that doesn't take care of it, some Meguiar's Scratch-X or their new Swirl-X would be my next try. And if that doesn't do it, 3M makes a fantastic, more aggressive (but still gentle) compound that I really love. It's part number 03900. I buy it at Checker, but they don't keep it with the other polishes and waxes--they keep it on the paint prep aisle. You can apply this stuff with a foam applicator pad and it does a great job. Another product you can use safely with a random-orbit buffer is Meguiar's Dual Action Cleaner/Polish, #83. Again, it's safe and easy, but you really do need a buffer with a foam pad to get the most out of it.
Good luck! Remember, all cars have paint issues. I know where all of mine are so they don't freak me out each time I wash and wax. Fix what you can and live with the rest. If you routinely wash the car and keep wax on it, friends and onlookers won't have a clue where the flaws are and you'll always get compliments.
GM Kid is offline   Reply With Quote
Old 06-07-2009, 08:05 PM   #11
2010 SS RS
2010 SS RS's Avatar
Very good explanation GM.
Old 06-07-2009, 08:13 PM   #12
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
What color is your car Adam?...Personal experience, water blade and absorber work awesome if used gently and properly (on a "clean" car).
Make sure you wash your Absorber frequently too...keep it as clean as possible and store it damp in its tube.
GMtothecore is offline   Reply With Quote
Old 06-07-2009, 08:58 PM   #13
Adam
You Said Member
mine's silver, the towels were new. washed them and dried them already since the car wash.
Old 06-08-2009, 09:43 AM   #14
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
Adam,
What polish, if any did you use? re; prior to washing?
A "trick" I've learned (on Zaino polished cars) is when rinising, remove the hose nozzle and let the water run over the entire car, which will cause 80 to 90 percent of the water to "sheet" away, leaving minimal drying.
I bought a half dozen 'Fieldcrest' "CHARISMA" towels from Macy's a few years back to use just for drying. I fold one in half, and with no pressure, lay it across the surfaces and pull it towards me. This removes the remaining water.
The "scratches" you seem to be describing can be either removed or "hidden" with a good polish. Silver is a very forgiving color too, so don't worry too much.
Let me know if I can be of any further help.
Ed
Moose is offline   Reply With Quote
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
2010 Camaro, Decisions Decisions… (Winding Road Review) Xmicro_SS 5th Gen Camaro SS LS LT General Discussions 19 05-09-2009 12:40 PM
Q&A with fbodfather (Scott Settlemire) regarding upcoming Camaro JustinZS 5th Gen Camaro SS LS LT General Discussions 22 05-20-2008 08:48 PM
