Gen5DIY
Old 11-25-2012, 07:52 PM   #1
MaroMike94
Drives: 2012 camaro lt
Supercharger boost question
How much boost does the ipf supercharger put out with just the supercharger installed?
MaroMike94 is offline   Reply With Quote
Old 11-25-2012, 08:54 PM   #2
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
People have run different boost levels from what I have read. It has ranged from 7-10# boost
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 11-25-2012, 08:59 PM   #3
MaroMike94
Gotcha. You can run more though cant you?
Old 11-25-2012, 09:24 PM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
with a pully change, but thats not fully supported.....yet.....
Old 11-25-2012, 11:58 PM   #5
V6owner
V6owner's Avatar
Sycraft is correct for the IPF SC
RX is capable to up a pulley for more boost
Old 11-25-2012, 11:59 PM   #6
Frans96ss
Frans96ss's Avatar
Drives: 96SS
Give us a call if you are looking to have one installed
Frans96ss is offline   Reply With Quote
Old 11-26-2012, 05:33 AM   #7
ASH@IPF-TUNING
ASH@IPF-TUNING's Avatar
Drives: 4x4 Turbo
Hello !
We tested smaller SC Pulleys for the LFX Camaro during our development .. we got more boost .. of course .. but NOT more power !!
Every engine has its maximum (optimum) cylinder pressure level ... when you are running toooooo much boost on a certain compression level ... you must run LESS ignition advance with higher BOOST to keep the engine away from knocking ... therefore you can also run the engine MORE Rich below AFR10 but you are loosing power anyway !
So MORE BOOST is NOT giving MORE POWER all the way ... we testet the optimum between boost level and engine power and deliverd the optimum boost level with the IPF-SC Kit for the bone stock engine and 91Oct west coast fuel qualtity with the devil heat in Arizona !
with 93Oct east coast fuel we did special tuning maps to cover the fuel quality !
regards ASH@IPF-TUNING
ASH@IPF-TUNING is offline   Reply With Quote
Old 11-26-2012, 08:14 PM   #8
MaroMike94
Isn't the v6 supposed to run regular unleaded?
Old 11-26-2012, 08:41 PM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
It can but it doesn't mean it's supposed to. The reality is that at regular unleaded, the car is pulling a lot of timing and can be running a lot better with 93 octane. You even get better MPG at higher octane (well at least I do).
Old 11-26-2012, 08:55 PM   #10
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
+1
Can't_C_Me is offline   Reply With Quote
Old 11-27-2012, 10:47 PM   #11
MaroMike94
Thanks, i guess I'll start using premium!
Old 11-28-2012, 08:05 AM   #12
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I believe the lower octane is inpart of the direct injection into the cylinder not on top of the intake valve. But with more boost higher octane helps out alot.
Old 11-28-2012, 09:44 AM   #13
MaroMike94
Okay, that makes sense. Will the supercharger decrease my gas mileage?
Old 11-28-2012, 10:09 AM   #14
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Overall my MPG is about the same with the IPF SC. This is when I'm doing about 70% highway an 30% city driving. I'm holding at about 23 mpg. However when you have this kind of performance increase you want to use it
I see a slight increase on highway and a decrease in the city
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
