Old 11-28-2012, 05:21 PM   #1
Smart Line
Smart Line's Avatar
Drives: 2011 Blue1SSRS 623RWHP, 02 vette
what should my AFR be at idle
finally got my gauge in and now wondering what it should be at idle?
2002 Vette (stock)
Team LS-3
Smart Line is offline   Reply With Quote
Old 11-28-2012, 05:39 PM   #2
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Between 14.5 and 14.9.
14.7 is perfect.
But it would depend on the combo.But these are popular numbers for the average car.
Motion427 is offline   Reply With Quote
Old 11-28-2012, 05:39 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
around stoich which is 14.7 for gas. if its digital it may bounce around some but should avg out to about 14.7
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 11-28-2012, 05:46 PM   #4
Smart Line
Smart Line's Avatar
thanks
2002 Vette (stock)
Team LS-3
Old 11-28-2012, 05:53 PM   #5
Smart Line
Smart Line's Avatar
sorry to be so clueless but at WOT what is the least it can go.
thought i read 12?
2002 Vette (stock)
Team LS-3
Old 11-28-2012, 06:41 PM   #6
Indyblue98
2012 RS 2ss
Drives: 2012 2SS RS L99 WhippleCharged
thought i read 12?
12 is ok , with a supercharger you want to be a little rich for safety.
Lower is not a real problem , its high numbers which means leaner , that would be trouble.
I think you need wide band sensor to be accurate when going very far beyond the 14.7 number in either direction
2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+KW V3 Coilovers
Indyblue98 is offline   Reply With Quote
Old 11-28-2012, 07:32 PM   #7
Motion427
I would suggest between 11.0-11.5 AFR.
Some push it to 11.8
I would be scared running it at 12.0
These numbers are for force induction numbers.
Been running 11.2-11.5 AFR with a TVS in my Avalanche for 2-3 years now.Works perfect.
Old 11-29-2012, 11:25 AM   #8
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
thought i read 12?
Just don't go into the 10's very much or for very long. It is bad for cylinder lubrication to go too low. Stay above 11.0 and all is happy. Most like 11.5.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 11-29-2012, 11:25 PM   #9
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 04-04-2013, 10:52 PM   #10
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
What should it be cruising on highway? Say 6 gear maintaining 70 mph about 1750 rpm steady.
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 04-04-2013, 11:02 PM   #11
kissmyss03
kissmyss03's Avatar
Drives: 2011 Camaro SS 2SS/RS
I'm between 12 and 11.6 throughtout a wide open pull
2011 Camaro 2SS/RS M6
Kooks Headers, catless mids, corsa exhaust, rotofab intake, SLP TVS 2300, 3.2 pulley, blower cam, cts-v fuel pump, Vector tuned 622 RWHP 573 TQ
kissmyss03 is offline   Reply With Quote
Old 04-04-2013, 11:08 PM   #12
JHall651
JHall651's Avatar
I want to know just cruising
Old 04-05-2013, 08:01 PM   #13
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Between 14 and 15 it will bounce around depending on throttle. Don't watch it too much. When you nail it it should stop bouncing and stand still around 11.5.
Mchlgrrsn is offline   Reply With Quote
Old 04-05-2013, 09:03 PM   #14
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
If your sensor is behind the cats it will be very steady and in the mid 14's. if it is in front of the cats it will oscillate, and you will see upper 13's to mid 15's. These are part throttle numbers of course. Sensor needs to be in front of cats to be accurate.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
