ADM PERFORMANCE
Old 12-02-2012, 05:38 PM   #29
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Originally Posted by muscle96ss View Post
So with it wide open would you say that there is a significant difference between it and the stock wide open? For example while revving it or while accelerating fast; can you hear a considerable difference?
yes, you can when revving it.
I think that the tubing for the actuators are too small, stock ones are hard plastic and very big.
I will post a pic after dinner of the stock vs. what I had to plumb, the stock will not work.....unless you cut or have access to make this??? We shall see.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 12-02-2012, 06:14 PM   #30
scottzl1
scottzl1's Avatar
Drives: 2017 ZL1
Hold up!
So, in a nutshell, is the LOUD side louder than stock (if so, very noticeably)? I just ordered this and I wanted quite a bit louder...but still have control with m2w.
Scott
scottzl1 is offline   Reply With Quote
Old 12-02-2012, 06:23 PM   #31
SamHouseIII
I Carry!
Originally Posted by scottzl1 View Post
Hold up!
Scott
Louder than stock on start up, but not overly loud. At highway speeds it is not loud at all, very quiet compared to stock. Again I don't know if the tubing that I re-plumbs that it is not working correctly, I did go out tonight and check the vacuam to make sure that it closed and opened the actuators, Mannualy that is. Still need to get the exhaust from rubbing in spots before I takle that beast.
Old 12-02-2012, 06:30 PM   #32
scottzl1
scottzl1's Avatar
Drives: 2017 ZL1
Are you thinking that the actuators may not be working properly so you might not have them open at WOT? I sure hope that is the case because my kit is being built this week and scheduled to ship on 12/7 and I really wanted quite a bit louder than stock...withe the baffles open of course. I know the tone is probably more aggressive but the volume interests me more...
Scott
Old 12-02-2012, 06:34 PM   #33
scottzl1
scottzl1's Avatar
Drives: 2017 ZL1
Thanks for your info and input btw
Old 12-02-2012, 06:35 PM   #34
SamHouseIII
I Carry!
Scott
No problem....someone had to take the plunge first.....lol
Old 12-02-2012, 06:59 PM   #35
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
Billy Boat ZL-1 exhaust cammed and long tube ARH headers......
RBD is offline   Reply With Quote
Old 12-02-2012, 07:22 PM   #36
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Did you do something to make the tips stick out that far, or is that just how it is? Any drone with the Billy Boat and headers?
2010 IOM Camaro 2SS/RS manual trans (Sold)
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-02-2012, 07:24 PM   #37
RBD
RBD's Avatar
mine was a prototype......no drone at all in quiet mode
Old 12-02-2012, 07:30 PM   #38
SamHouseIII
I Carry!
Nice car, I see the tips stick out way to far on the passenger side on yours too. I had to cut mine back a little, also mine are on the ZL1, which things are different than on an SS.
Old 12-03-2012, 10:12 AM   #39
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for sharing!!! I like that it's a larger tube and all SS.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 12-03-2012, 12:43 PM   #40
SamHouseIII
I Carry!
Crisis averted, no more rubbing, only cost $40 and about 40 minutes for them to fix. Shop aligned the pipes, no more rubbing on drive shaft, belly tin or rear pumpkin. No rattles or anything!! I had tucked the pipes up too much into the tunnel, causing the pipes to be pulled up too high, thus causing the rubbing issues. Yes, cutting back the pipe was right, because the pipe/muffler was not aligning with the hanger. Yes the Flapper is also working correctly, however I want to plumb the hard lines back in.
The big question of how does it sound?
Stock operations, no M2W switches….On start up, acceleration, deceleration and WOT it is deeper than stock. At cruising speed it is quieter than stock.
With the M2W operating, it is deeper than stock at all areas.
I will say that to me it is not louder than stock, just deeper. But I do have severe hearing loss?
Also it is much heavier than stock.
Old 12-03-2012, 07:23 PM   #41
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
How much weight does the bb add?
MrDew is offline   Reply With Quote
Old 12-03-2012, 07:28 PM   #42
SamHouseIII
I Carry!
? Don't know, but it's more!
