Caryle Racing
Old 12-02-2012, 01:03 PM   #1
racer3j
Drives: 2011 Camaro RS
What would it take to make my own supercharger kit?
What would it honestly take for me to go out buy a Vortech V3 supercharger and build my own kit around it? What components are needed in order to do this?
Summit White 2011 2LT RS Camaro. K&N Cold air intake, Magnaflow cat back exhaust, Black out kit.
racer3j is offline   Reply With Quote
Old 12-02-2012, 01:52 PM   #2
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Piping, tune, clamps, couplers, MAF tube, pullies, etc etc
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 12-02-2012, 02:06 PM   #3
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
A lot of engineering is involved with just the mounting brackets.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 12-02-2012, 02:10 PM   #4
Supermaro585HP
Drives: 2011 Camaro SS RS
A supercharger!!!
Supermaro585HP is offline   Reply With Quote
Old 12-02-2012, 04:23 PM   #5
blackTT600
Drives: 2011 2LT M6 SC
Lots of hair tarring out, specially if its your daily.
blackTT600 is offline   Reply With Quote
Old 12-02-2012, 05:26 PM   #6
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Honestly, it's not that hard at all. My friends and I built a turbo kit for a scion tc completely from scratch. The only thing is you will constantly have to be monitoring it and always be prepared for something to go wrong. If it's your daily driver, I would not recommend it at all. But can it be done? Sure.
Another thing though, is that we don't have a tuning software to tune things and mess with things ourselves. When we built the tc kit, we could always tune it and see how things were doing and change things but you can't with this car. You always have to be waiting for someone to get back to you on the tune.
Old 12-03-2012, 11:20 AM   #7
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
pipes and the head unit is esay, the tune and cables are what you need unless you have access to a dyno shop
Old 12-03-2012, 11:27 AM   #8
Nutbutt
Nutbutt's Avatar
The tune is the gold nugget in the whole system. If you have an LLT working with a Bosch ECM is a mystery unless you have their proprietary files and know how to use them
Old 12-03-2012, 11:50 AM   #9
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Really not fair to compare a turbo to a SC... You can get creative with your piping and placement of your turbo.. .however on a SC, since it's belt driven you are a lot more limited with it's placement... and as NutButt pointing out mounting the SC is going to be pretty involved...
scrming is offline   Reply With Quote
Old 12-03-2012, 11:54 AM   #10
lscamaro
lscamaro's Avatar
True. The turbo we built was a front mount so it was still in the same vicinity a supercharger would be in but I understand what you're saying.
Also, as stated, the tune is what's going to get you. Unless you can find a way to tune it reliably, you're efforts are going to be in vain.
Old 12-03-2012, 02:31 PM   #11
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I'd try to build a custom turbo kit before a SC kit.
DarkneSS is offline   Reply With Quote
Old 12-03-2012, 07:10 PM   #12
twmotox
twmotox's Avatar
Drives: 2013 Camaro 1LT RS
I know this is oversimplifying it greatly but GM has produced several cars with factory Roots blowers, could you find a used one and make and adapter plate to make it fit the llt or lfx intakes? I am also very curious if you could take an LFX and make an adapter to bolt turbos directly to the cylinder heads. Just a few thoughts.
Loyalty above all else except honor!
twmotox is offline   Reply With Quote
Old 12-03-2012, 11:04 PM   #13
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Heat sink turbo, unless you wrap it and feed it oil, the benifits are great, just don't forget to feed your bearings.
