B&M Racing
Old 12-02-2012, 02:22 PM   #1
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
Exclamation Semi-rough idling problem
Hey guys and happy Sunday,
Ever since I got the new cat (replaced by dealer), I have noticed that the car kinda rumbles when in park or is idling. It kinda feels like the mild ghost cam from trifecta. I am sure I do not have it on.
I still haven't gotten an updated tune after adding all of the mace products. I am working on it though. I sent in a log on monday and am still waiting for a response..
Can an outdated tune be causing this problem? Or could this be more serious than I think and maybe I should take it in?
BTW, I realized I never successfully installed the stock tune before I sent the car back to the dealership. They never noticed the tune. So for you guys wondering if it voids the warranty, it doesn't with the LLT.
Thanks for your input guys,
Niko
nikos30 is offline   Reply With Quote
Old 12-02-2012, 02:42 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Both o2 sensors connected?
Lil' Nasty is offline   Reply With Quote
Old 12-02-2012, 03:37 PM   #3
nikos30
HT5 EastSide
nikos30's Avatar
yupp
Old 12-02-2012, 08:18 PM   #4
nikos30
HT5 EastSide
nikos30's Avatar
110 views and one question? you guys got nothing? :(
Old 12-02-2012, 08:58 PM   #5
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Check the o2 and see if the installer got them dirty. Local auto parts store will have o2 cleaner if they are.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 12-02-2012, 10:31 PM   #6
nikos30
HT5 EastSide
nikos30's Avatar
Ok, I also heard my spark plugs could be bad. is that a possibility?
Old 12-02-2012, 10:40 PM   #7
Yellow_Glide
Wouldn't think so- how long since the work? Possible plugs may be an issue more likely it's sensor related.
Old 12-02-2012, 10:55 PM   #8
nikos30
HT5 EastSide
nikos30's Avatar
like 200 miles ago. and ok, thats what I was told by a friend who is pretty experienced.
Old 12-02-2012, 10:59 PM   #9
Yellow_Glide
Pull one and check.
Old 12-03-2012, 08:00 AM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
If you decide to replace'em, check the Denso ITV20 5339's. Threw a set in my car cause I got it in my head I needed to... .
But it does seem to be running quite strong!
Before you do though- I'd disconnect the battery and reset the ECM. Several members have related a smoother idle and generally improved running after resetting the trims and allowing a "re-learn".
Old 12-03-2012, 10:31 AM   #11
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Check the plugs, if they are real black clean them off with a wire brush and then spray them with brake cleaner. These engines run rich, so before spending on plugs try it! Also spray off your MAF as you could of got some contaminants on it. Either of these 2 can cause rough idle.
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
camaroprobs, ghost cam, idling, llt, v6er
