BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 12-03-2012, 02:22 AM   #1
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
Ni Cad vs Lithium Ion
Ni Cad vs Lithium Ion - do LI actually increase power at all or is iot just that it lasts near full power longer? Is it worth it for a weekend warrior if I have 3 Ni Cads to swap back forth too?
IPT is offline   Reply With Quote
Old 12-04-2012, 04:39 PM   #2
LessSinister
Drives: 2011 - 2LT/RS Convertible
The biggest reason to avoid NiCad is the "memory" effect. That is, if you recharge when it's half-full the then next time it will only charge to 1/2 capacity. More or less. There may be other benefits of LI but that was a deal breaker for any of my power tools.
LessSinister is offline   Reply With Quote
Old 12-04-2012, 08:01 PM   #3
Synner
Drives: not stock
Depends on how its being compared. Typically its duration, holds a charge better in-between uses, and lasts longer. Li requires a special charger with additional circuitry.
Personally I prefer corded, especially if more torque is your goal. Cheaper brands of battery tools are just that, cheap. If what you have is meeting your goals and use then its a waste of money to upgrade.
Old 01-09-2013, 09:06 PM   #4
Rhyno81
Drives: Summit White 2012 2SS RS M6
Li Ion works on the "Full power or no power" principle. meaning it has max power until it loses it charge and stops Ni Cad is always slightly declining from a full charge
2012 Summit White 2SS RS M6
-Factory Hurst Shifter
-Cold Air Inductions CAI
-TSP 1 7/8" long tubes with high flow cats
-Muffler Delete
-Matte Black Powdercoated 20"SS Wheels (General GMax Tires)
-BMR Strut Brace
Rhyno81 is offline   Reply With Quote
Old 01-09-2013, 09:42 PM   #5
SimpleGreen
Drives: 2013 1SS/1LE IOM
Definitely Lithium-Ion, most for due to the longevity of the batteries. My Makita 18V drill is going on nearly two years old and I use it daily at work. It has tons of cycles on the batteries (Li-ion). Actually, all my power tools are Li-Ion now at home and work.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 01-12-2013, 02:03 PM   #6
cfodor
Drives: Chevrolet
I have had both and the li batteries are getting better. I had 36 volt dewalt stuff when it first came out and the batteries did not last that long. You were lucky if you got a year out of them before they would go bad. I have a snap on 18v nicad impact and the batteries have been good for 3 years
cfodor is offline   Reply With Quote
Old 01-12-2013, 02:17 PM   #7
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
My lithium ion dewalt drill/impact I got last yr is the best I have ever had. Lighter weight ad the battery lasts much longer
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 03-12-2013, 10:22 PM   #8
DR TOOLS
DR TOOLS's Avatar
Drives: 2012 2ss 45th Anniversary
No one mentioned nimh batteries. No instant cut off, no memory effect and have a high discharge rate. Also greener than both. Can use same charger as NiCd. Only pro for lion is its lighter in weight.
DR TOOLS is offline   Reply With Quote
