JUICEDMOTORSPORTS
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California > Local Marketplace
Old 12-03-2012, 05:18 PM   #1
swagdawg
Drives: 2010 camaro
Arrow 2010 New GM Chevy Camaro LS3 complete motor with accessory drives; 430 HP rated
2010 New GM Chevy Camaro LS3 complete motor with accessory drives; 430 HP rated - $6800.00
LS3 6.2L Tech Specs
Part Number:
19201992
Balanced:
Internal
Block Part Number:
12584727
Block Type:
Cast aluminum with 6-bolt main caps
Bore x stroke (in):
4.06 x 3.62 (103.25 x 92mm)
Camshaft duration (@.050 in):
204 degree intake / 211 degree exhaust
Camshaft Part Number:
12603844
Camshaft Type:
Hydraulic roller
Compression ratio:
10.7:1
Connecting rods (P/N 12617570):
Powdered metal
Powdered metal
Crankshaft (P/N 12597569):
Nodular iron
Nodular iron
Cylinder heads (P/N 12598594):
LS3 rectangle port; as cast with 68cc chambers
Displacement (cu in):
376 cu in (6.2L)
Engine type:
LS Series Gen IV small-block V-8
Maximum recommended rpm:
6600
Pistons Part Number:
19165089
Pistons Type:
Hypereutectic aluminum
Recommended fuel:
92 octane
Reluctor wheel:
58X
Rocker arm ratio:
1.7:1
Rocker arms exhaust Part Number:
10214664
Rocker arms exhaust Type:
Investment cast, roller trunnion
Rocker arms intake Part Number:
12569167
Rocker arms intake Type:
Valve Lift (in):
.551 intake / .522 exhaust
Valve size (in):
2.16 intake / 1.59 exhaust
swagdawg is offline   Reply With Quote
Old 12-03-2012, 07:38 PM   #2
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
I know someone interested in NorCal, however the price will be more than he's willing to pay. If you can PM me your contact information I'll pass it along and let you two hash out the details.
Falundir is offline   Reply With Quote
Old 01-09-2013, 06:09 PM   #3
Adorso87
Drives: Black 2010 Camaro 2SS
I'm on the look out for a used ls3, price is a little high but if its still available message me and we can work something out.
Adorso87 is offline   Reply With Quote
430 hp, chevy, ls3, motor
