SDTW Custom Wheels & Tires
Old 12-03-2012, 05:26 PM   #1
markgws6
markgws6's Avatar
Drives: 2013 Camaro 1SS/1LE
Latest GM Update?
Is there a way to tell whether I have the latest GM MDI update installed in my car? Is there a number or code that gets printed out if I take it down to say Autozone for them to read it? I need it for a tune and I'd rather not waste my time at a dealer if I don't have to...
2011 1LT (LLT V6 Auto)
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43)
CAI intake, Apex cold air scoop and washer bottle, Hypertech 91 tune, ZR1 diff fluid, Motul RBF-600, Russell SS brake lines, SLP skip-shift override, SRP Pedals, Forza 3 way exhaust controller, octane fuse reset
markgws6 is offline   Reply With Quote
Old 12-03-2012, 10:12 PM   #2
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Try this link you can have a peek of your system from GM
http://tis2web.service.gm.com/tis2web
enter your VIN number & it will show you status of all your systems.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 12-03-2012, 10:23 PM   #3
markgws6
markgws6's Avatar
Is this a current status of the systems or is it just the possible updates for my VIN?
(1 of 43)
Old 12-03-2012, 11:04 PM   #4
Kiwi_Camaro_2010
Everytime your car is plugged in at dealer, If they do any updates to your systems it gets logged onto this website for GM, so it should be exactly what status your car is at currently & will show if any new updates are available for your vehicle. You can update your system yourself if you have say a mongoose pro cable & pay for day's subscription to access updates via internet, you must be plugged in to your car while accessing internet. this is what I did before I started modding my car, so I knew I had latest updates first.
Old 12-04-2012, 09:56 AM   #5
markgws6
markgws6's Avatar
So it shows the updates but did not show anything new or different...does that mean I have the latest? Sorry but I've never seen this before...
(1 of 43)
Old 12-04-2012, 01:51 PM   #6
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
How do u tell if its up to date?
Looking at the detailed history option, I see the columns:Part number, CVN, bulletin #, and description. The CVN column shows a part# or N/A and the bulletin column has "-"
cmore is offline   Reply With Quote
Old 12-05-2012, 01:04 AM   #7
Kiwi_Camaro_2010
To be honest it was over 6 months ago when I did it, so bit vague, what i can remember when you go to next screen & select what area you want to check if it needs an update you can expand drop down menu. Each update is numbered & you check number sequence to see if there is a higher number available for that section than what your listed at at moment, as far as I can remember to update you have to go through each system menu & check drop downs as system cannot be updated as a hole but by individual system downloads on each parameter. i would suggest if your not sure take it to a dealer to update, as you can make it alot worse if done wrong. One update I did on stereo kill audio output then lost usb support, had to reflash it twice to bring it all back. Because where I live I have no dealer support or warranty so did it myself.
Old 12-15-2012, 02:26 PM   #8
markgws6
markgws6's Avatar
Thanks for your help. I just went in and had the dealer check it. It had the latest ECM updates but not the BCM so they updated it.
(1 of 43)
Old 12-16-2012, 01:38 AM   #9
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
So you went to the dealer after you had the car tuned? How did that go?
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 12-17-2012, 07:11 PM   #10
markgws6
markgws6's Avatar
No. I went there before I tuned the car. The tuner (IPF) said I needed the latest GM updates because that is what their calibrations were based on.
But I'd had the hypertech tune installed before and I just returned it to the stock tune and they said nothing about that lol.
(1 of 43)
