Cold Air Inductions
Old 12-04-2012, 03:05 AM   #1
was619
Billy The Kid
was619's Avatar
Drives: Cyber Grey 2SS/RS
Cam'ed LS owners- Help with Quiet Exhaust search
Hey All,
I have OBX LT and HF cats, with the Stainless Works Retro Chambered 3 inch catback (factory size hook up)
I have a good bit of drone at highway speeds and have been looking at other options to lower the volume out back before doing a cam instal this spring.
So any suggestions from those of you that have heads/cams ect (pushing more air through) would be greatly appreciated on what would be a better/quieter option.
I have been considering borla, corsa ect.... but it seems that many of these get much much louder after the addition of a cam. maybe dynomax...?
Thank you in advance!
also lets try to avoid the "louder the better" type comments please
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension,
MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners
Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels
was619 is offline   Reply With Quote
Old 12-04-2012, 03:25 AM   #2
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
I have no real world experience. However, both my last camaros were loud and I am not looking to do that again. This time around when I put the headers on I plan on going with the Magnaflow Street system. I've read it's a bit tame but wakes up nicely with headers. I would imagine with a cam too it'd sound mean, but not overhwelming.
IPT is offline   Reply With Quote
Old 12-04-2012, 08:45 AM   #3
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
Factory LS3 catback, paint the cans black. Or, Magnaflow street.
Corsa or the factory system won't drone, but the Corsa is loud.
Old 12-04-2012, 08:54 AM   #4
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
I'm honestly trying to find those answers also. The magnaflow street quiets it down but still drones pretty bad on highway and sounds like a poppy glasspack under WOT.. I hated it and went back to my louder system until I found an answer. I wonder if anyone has good video of what the factory catback sounds like with an H/C setup.. Id be interested in putting mine back together ( i had originally done a muffler delete.) add some bigger tips paint the cans black and go from there.
The 2010 Sin is offline   Reply With Quote
Old 12-04-2012, 08:58 AM   #5
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
My Corsa is quiet at idle and cruising speeds with no drone but LOUD at WOT.
DarkCry956 is offline   Reply With Quote
Old 12-04-2012, 09:43 AM   #6
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Corsa!
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 12-04-2012, 09:52 AM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
My Magnaflow street does not do this at all. Are you sure you had the 3 muffler system?
Old 12-04-2012, 10:11 AM   #8
VADER SS L99
To the OP. I have LT's with cats, cam/heads, and the Magnaflow street and it is very quiet considering the mods. My car gets mistaken for a stock SS all the time and I love it that way. Sounds like a stock car with a mild axle back at idle. Turns into a complete beast under WOT. The combo should be sold together and named Jeckle and Hyde. It has slight drone at highway cruising but you have to turn the radio all the way off to hear it and it didnt do that until after the cam. You cant use the stock catback because the cam will destroy it. Only other catback that I can think of that you might look into is the Dynomax VT but I always worried about the valves not working. Corsa is not going to drone but it will be loud. Even the L99 Corsa system will be louder than the Magnaflow street. I honestly cant think of a quieter system.
Old 12-04-2012, 11:47 AM   #9
TRIPWIRE
Chillin Like a Villain
TRIPWIRE's Avatar
Drives: 2013 2SS Blue Ray Metallic Dusk Ed.
i have corsa with lts cats and a cam and its loud as **** i wouldnt recommend it if your looking for quiet
TRIPWIRE is offline   Reply With Quote
Old 12-04-2012, 11:54 AM   #10
SPCBA
Drives: pleather and Chiclets
Being loud and having drone are two different things to tackle. A J-pipe can kill your drone. Only a quieter exhaust can change the volume. A quieter exhaust does not exactly transfer to no drone.
SPCBA is offline   Reply With Quote
Old 12-04-2012, 12:02 PM   #11
Birm
Birm's Avatar
Drives: Florida Speed & Power
Go back to a 2.5" exhaust or get the Dynomax VT! I had it with my LTs and Cammed car and it was too quiet for me, here is an idle video:
http://www.camaro5.com/forums/showthread.php?t=221083
Birm is offline   Reply With Quote
Old 12-04-2012, 12:50 PM   #12
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Borla Touring is pretty tame at idle. I currently have it with LTs and Cats. Will be doing a cam swap in March.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
Texas Speed UD Pulley
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 12-05-2012, 06:53 PM   #13
The 2010 Sin
Yes I've owned the Magnaflow street 3 muffler catback and the competition one center muffler catback. as well as the Flowmaster American Thunder catback which I currently have on the vehicle until I get something else.
Old 12-05-2012, 06:57 PM   #14
The 2010 Sin
I think I'm going to try and twist my local ZL1 guys arms for their factory catback when they upgrade and go to a quad tip setup
cam, exhaust, ls3
